Author Topic: what type brake oil after rebuild s2  (Read 402 times)
Offline mike alain
« on: Saturday,January 23, 2021, 05:06:28 AM »
Folks, i bought aftrmarket triumph master cylinder and ebay rear brake cylinders and aftermarket pistons on front calipers,   do I use girling oil like
car came from factory or just dot3  .   thanks  Mike from Montreal.
Re: what type brake oil after rebuild s2
« Reply #1 on: Saturday,January 23, 2021, 06:15:45 AM »
Before I switched to silicone brake fluid,I had to rebuild the brakes and boosters all the time.
I switched to silicone brake fluid 25 years ago and would never switch back.  Everything should be new before you switch though.
Just my two cents worth.
« Reply #2 on: Saturday,January 23, 2021, 06:44:48 AM »
I run DOT 4 in mine, no issues.  DOT 3 would be ok as well but I standardized on one brake fluid for all my vehicles.
