Author Topic: our Jetting for single Weber 45DCOE on Hermes Renault Engine?  (Read 393 times)
Offline R16TS
« on: Friday,January 22, 2021, 05:12:55 AM »
expect from the Haynes Theoretical Datas, can you list your running Jettings from real live? I am unsure what jets to buy.
Offline SwiftDB4
Re: our Jetting for single Weber 45DCOE on Hermes Renault Engine?
« Reply #1 on: Friday,January 22, 2021, 08:54:45 AM »
This info is from an Else conversion 45DCOE carb I had years ago:
Main fuel jets 155
F7 Emulsion tubes
Idle jets 50 F8
Pump jet 50
Chokes 36
Sorry no main air corrector number
« Reply #2 on: Friday,January 22, 2021, 01:01:34 PM »
I think the recommendation in the Haynes Weber book is a good starting point.  Regardless of what starting point you use, you will still have to dial it in to suit your local area.
