Author Topic: TCS axle bearing  (Read 1743 times)
Offline kram350kram
TCS axle bearing
« on: Monday,January 04, 2021, 07:47:48 PM »
Can anyone confirm the bearing #6206 for both inner and outer? 30x62x16? Thanks
Re: TCS axle bearing
« Reply #1 on: Monday,January 04, 2021, 08:06:17 PM »
According to the Golden Gate Lotus Club the inners all Europas are: SKF or FAG 6206 2RS; NSK6206VVC3E-CSR1S5; NTN 6206LU, NTN6206LB
And the outers for the Specials are:    SKF or FAG 6206 2RS
« Reply #2 on: Monday,January 04, 2021, 08:07:27 PM »
I thought it was 6206 outer and 6006 inner.
« Reply #3 on: Monday,January 04, 2021, 08:08:33 PM »
... get -2RS versions, of course.
« Reply #4 on: Monday,January 04, 2021, 08:15:57 PM »
Hmm, according to the online parts manual and cross reference at lotus-europa.com
S1/2 & TCS  6006/31 (ID=31mm)
TC  6006 (ID=30MM)
Doesn't make sense to me.  The TCS came after the TC.  Why would they go back to the funny, hard to find, expensive bearing?
« Reply #5 on: Monday,January 04, 2021, 08:37:46 PM »
RD lists the TCS rear axle bearings as the same for both the inner and the outer.  So a pair of 6206-2RS bearings it is for the TCS.  Makes more sense.
« Reply #6 on: Monday,January 04, 2021, 08:38:11 PM »
Make sure you have hardened spacers.
Offline Dilkris
« Reply #7 on: Tuesday,January 05, 2021, 12:19:48 AM »
 :I-agree: Presently have mine (TCS) disassembled so can confirm same bearing (6206 2RS) - this is likely to start a discussion based on if they are 2RS, (sealed both sides), do you really need the oil seal on the inboard side of the hub..... ?:FUNNY:
« Reply #8 on: Tuesday,January 05, 2021, 05:55:51 AM »
Helps control moisture ingress due to condensation.
« Reply #9 on: Tuesday,January 05, 2021, 12:26:07 PM »
CW removed the inner seals on my car, drilled the castings for a grease zerk and pumped grease in the housings and said he has not had to install another set of bearings since he did that.
« Reply #10 on: Tuesday,January 05, 2021, 12:39:51 PM »
The rear uprights are hollow.  That's a lot of grease.
John
« Reply #11 on: Tuesday,January 05, 2021, 03:59:28 PM »
We will see how they look when I get to the point of disassembling them....and how much grease is in them
« Reply #12 on: Tuesday,January 05, 2021, 05:14:24 PM »
John
I would venture to guess that you would pump almost an entire cartridge in to the upright.  :huh:
Offline kram350kram
« Reply #13 on: Tuesday,January 05, 2021, 05:56:38 PM »
I see there is a dust seal on the inside at the u-joint but not on the outside bearing? What other than the bearing seal seals the outside bearing?
« Reply #14 on: Tuesday,January 05, 2021, 06:33:22 PM »
Unsprung grease, too.  ;D
