That's a neat idea, do you have two servos for a dual circuit with a matching servo on the other side or are you on single circuit ?
Brian.
Thanks Brian!
Yeah. I have twin boosters. I kept the Federal brake circuit so of course I had to adapt it for the different locations for the boosters. The other is behind the other rear wheel. The plumbing didn't come out as neat as I wished but it is hidden by the trunk so I only care a little bit. Doing it this way allowed me to but a panel of electronic stuff where the boosters were. It holds a rev limiter, a fuel pump relay, a GPS antenna, some fuses and the emissions plaque
. The picture is old and I have a Pertronics rev limiter now and maybe another small change or two but you can get the idea.
I should note that just as the original boosters mounting points are backed up - originally there was a piece of sheet metal on the other side of the fiberglass where the boosters were mounted - I did the same thing.
