Author Topic: Fuego Turbo engine on eBay  (Read 1183 times)
Offline gideon
« on: Tuesday,December 08, 2020, 06:55:35 AM »
This listing is from a Europa owner in Vermont.  He also has some NG transaxles and a pile of assorted parts to sell
https://www.ebay.com/itm/Renault-18-Carbd-Turbo-1565cc-A5L-Lotus-Europa-Matra-Djet-A110-A108/224269086227
Does anybody know the seller?
Offline Chuck Nukem
Re: Fuego Turbo engine on eBay
« Reply #1 on: Tuesday,December 08, 2020, 11:53:14 AM »
Thanks for posting this! I have a 71 S2 that has a turbo fuego motor that is fuel injected. This car came to me with the motor in sad shape. This would be the perfect drop in swap!
« Reply #2 on: Tuesday,December 15, 2020, 07:27:42 AM »
 :FUNNY: :FUNNY: :FUNNY:
  okay who is G**2  ??? you outbid me.
 Its fine I just marked the page because of all the other items in pics.
 dakazman
Offline Music City Lotus
« Reply #3 on: Tuesday,December 15, 2020, 01:42:59 PM »
Didn't meet reserve.
1971 Lotus Europa Type 65
« Reply #4 on: Wednesday,December 16, 2020, 02:47:40 PM »
    I'm torn AGAIN.
  Its not a need but a want. I can get by with what I have .
  Its all yours Chuck. however ask for a picture of the motor mount bolt position on block. but then why would a lotus owner have it in his collection if it didn't fit.
Offline Chuck Nukem
« Reply #5 on: Thursday,December 17, 2020, 06:36:51 PM »
    I'm torn AGAIN.
I'm in the same position. Not a need, but a want. Its fair game!
« Reply #6 on: Thursday,December 17, 2020, 06:59:05 PM »
 Chuck,
  I have one and will test the blocks’ head bolt threads tomorrow by bolting down the head and rockers with a used gasket . If it can reach 65ft lbs ...I’m good.  Merry Christmas.
Adding an AC compressor on it is more difficult than the wedge but it can go if you settle for a DGV carb intake manifold. Definitely not with dual Weber’s’.  On the header side ,.. testing that soon.
« Reply #7 on: Thursday,December 17, 2020, 08:33:31 PM »
You can put an AC compressor on a crossflow with dual sidedrafts.  I've done it.  It's not easy.  The main problem is that the overhung pulleys on the water pump can't take the tensions required to keep the AC belt from slipping.  I machined the water pump housing and modified the pulleys to fit a bearing to support the pulleys.
Basic layout:
https://jbcollier.smugmug.com/Lotus-Europa/i-HfnH25R/A
https://jbcollier.smugmug.com/Lotus-Europa/i-2XXJT3V/A
First mod, fit larger idler pulley to reduce stress on the belt:
https://jbcollier.smugmug.com/Lotus-Europa/i-Gs6fMpG/A
Supporting there overhung pulleys:
https://jbcollier.smugmug.com/Lotus-Europa/i-gRDNfvn/A
https://jbcollier.smugmug.com/Lotus-Europa/i-RNvKK4f/A
https://jbcollier.smugmug.com/Lotus-Europa/i-5bgmTXz/A
https://jbcollier.smugmug.com/Lotus-Europa/i-W5NSCcw/A
Then there's the issue of bumping the idle when the AC is on:
https://jbcollier.smugmug.com/Lotus-Europa/i-4pRB8Z4/A
Good?  Yes.  Completely satisfactory?  If I had to do it again, I'd fit an electric AC system.
Offline MRN I J
    • Four Ashes Garage
« Reply #8 on: Friday,January 15, 2021, 01:38:19 PM »
use toothed drive belt pulleys, these are a set that I made to drive the WP and Alternator for Andy Short's Fuego (R18) Turbo Europa, didn't work because i didn't hard anodise the pulleys
« Last Edit: Friday,January 15, 2021, 01:50:05 PM by MRN I J »
Regards Chris
other cars inc wifes cars
