Author Topic: What are the differences between the 336 gearboxes? 336-33  (Read 1215 times)
Offline yellow16TS
« on: Monday,December 07, 2020, 10:53:03 PM »
Hi everyone, after some searching online and searching through my workshop manual and Renault 16 engine workshop manual, I cannot find the answer to my question.
My S2 has the original 336-26 4 speed fitted.
I went to a self serve wrecking yard and removed a 336 gearbox (transaxle) from a Renault 16 car. I just want it as a spare because it was cheap + they are getting harder to find in Australia. I thought I could use it for parts if I end up requiring them later down the track when my Europa is on the road.
Since it is from a Renault 16 there are some obvious visual differences. (I was aware of this.) Bellhousing, clutch fork opposite side, end housing different, shift linkage totally different.
What I want to know is: what is a 336-33 gearbox? That is what this one is.
What does the -33 designate? All I can find from my Renault manual is that it means it is from a RH drive vehicle and "poor road type vehicles and special equipment" What does this mean exactly?
See attached picture from the Renault manual I have.
There seems to be a variety of models of 336. 20,21,22,23,24,25,26,30,31,32,33,34,35,36,37.
I am curious to know what these numbers mean.
cheers,
« Last Edit: Monday,December 07, 2020, 11:15:19 PM by yellow16TS »
Currently restoring 54/1103
Offline Bodzer
Re: What are the differences between the 336 gearboxes? 336-33
« Reply #1 on: Monday,December 07, 2020, 11:12:21 PM »
I wonder if it is strengthened in key areas to take tougher road conditions or longer periods between overhaul?
« Reply #2 on: Tuesday,December 08, 2020, 05:39:16 AM »
That's probably more information on the different types than I've ever seen.
Note that the R16 transaxle turns the wrong way for a Europa though other parts could be useful as spares.
Offline yellow16TS
« Reply #3 on: Tuesday,December 08, 2020, 02:46:26 PM »
Yep, understood.
As Bodzer said as well, I wonder if there is a difference in strength?
Or ratios? Maybe the gear ratios for the "poor road conditions" are taller?
« Reply #4 on: Tuesday,December 08, 2020, 03:31:15 PM »
Probably lower for more low speed work.
