Author Topic: Handbrake Lever mounting - TC - Help Please  (Read 1315 times)
Offline Dilkris
« on: Monday,November 23, 2020, 01:59:40 AM »
I need some help here please – the TCS I am rebuilding I, (foolishly), bought in pieces, so those “obvious” things on reassembly are not that “obvious” to me. I have searched the Forum and parts diagrams but cannot find the answer to this detail.
How is the lever mounted to the chassis? Please see photo’s
The lever and “pin” are shown cleaned, (they were seized solid), the mounting in the chassis is tapped 3/8” UNF and the lever boss obviously fits over this. But then I have the “pin” which is some 3” long and is tapped in a blind hole 3/8” UNF 20mm deep at one end and again a blind hole ¼” UNF and 12mm deep at the other.
What am I missing here? Or more to the point – what’s wrong?
Re: Handbrake Lever mounting - TC - Help Please
« Reply #1 on: Monday,November 23, 2020, 04:15:18 AM »
Hi Dilkris,
I don't know what that drilled/taped pin is about.
The reaction lever is retained with a simple shoulder bolt & washer.
Here's a pic of the TCS arrangement for a left hand drive car.
Cheers,
Gavin
Offline Dilkris
« Reply #2 on: Monday,November 23, 2020, 04:46:08 AM »
Thanks Gavin - that seems to make sense. It seems the mystery pin will remain a mistery !!
Out of interest - were did you get the "pictorial" from?
Chris
Offline Dilkris
« Reply #3 on: Monday,November 23, 2020, 04:48:04 AM »
Sorry - "mystery"  :-\
« Reply #4 on: Monday,November 23, 2020, 06:31:22 AM »
You can find an enormous amount of information here:
http://www.lotus-europa.com/manuals/index.htm
Owners/parts/service manuals, wiring diagrams, technical articles, etc.
« Reply #5 on: Monday,November 23, 2020, 06:44:19 AM »
Chris
It came from a "Body Removal" post referencing Phil Ethier, a long time Europa guy.
Here's the link - might be helpful for other stuff.
http://www.lotus-europa.com/manuals/misc/body/Body_Removal.html
Offline Dilkris
« Reply #6 on: Monday,November 23, 2020, 10:43:41 AM »
Thankyou JB Collier and Gavin - (all I managed to find was the below)  :headbanger:
Offline Broadside
    • Midland Race and Rally
« Reply #7 on: Monday,November 23, 2020, 11:27:09 AM »
I've been looking at my handbrake too, it seems that when the cable is taut the horseshoe touches the bottom of the coolant pipes, is that normal?
« Reply #8 on: Monday,November 23, 2020, 11:43:44 AM »
Mine is like this! http://www.lotuseuropa.org/LotusForum/index.php?topic=3266.msg33427#msg33427
There is a bit of a discussion about it there too!
Offline Broadside
« Reply #9 on: Monday,November 23, 2020, 01:19:33 PM »
Interesting, mine run through the rear chassis below the coolant pipes in separate holes, one each side. Nothing in the hole where your cables run
« Reply #10 on: Monday,November 23, 2020, 02:26:56 PM »
My handbrake cables do too, from the two holes linked by a slit. They have to so the handbrake outer cable ferules can seat in the holes.
The two you see with the outer cables are the speedo and choke I believe (as it's from memory!).
I couldn't get the horseshoe to sit above, or below the pipes, though I have not removed and refitted it to try. The consensus seemed to be that its unlikely to wear through the pipes before they rust!
« Reply #11 on: Monday,November 23, 2020, 02:58:40 PM »
Look in other manuals:
Offline Broadside
« Reply #12 on: Monday,November 23, 2020, 03:10:44 PM »
Ah right, just read some more of your thread, so mine is correct running below the pipes in theory :-)
Offline gideon
« Reply #13 on: Monday,November 23, 2020, 07:19:49 PM »
There's a labeled diagram of S2 rear bulkhead holes, here
http://lotus-europa.com/manuals/s2misc/framebulkhead.jpg
« Reply #14 on: Monday,November 23, 2020, 09:44:41 PM »
One of these mounted above the coolant pipes would make adjustments so much easier.
