Author Topic: Fuel Tanks - A bit of Useful info - maybe  (Read 1116 times)
Offline Dilkris
« on: Wednesday,November 18, 2020, 10:58:25 AM »
They say pictures tell a story so please see below. Was in the process of cleaning out and preparing the inside of the tanks and needed to blank all openings - after much head scratching discovered that a tow ball cover works great for the filler openings.
As a separate point, modification to the sender fitting was made due to the original "lock ring" being corroded, (and I also personally didn't like the arrangement). Photo shows this modified lock ring holding in a temp blanking plate, (which I finished sizing on a lathe hence the blanked centre)
Maybe useful info for others - if not already known.
Re: Fuel Tanks - A bit of Useful info - maybe
« Reply #1 on: Wednesday,November 18, 2020, 11:05:09 AM »
Interesting... How did you put those screws from the inside into your plate over the fuel level sender hole??  :huh:
Offline Dilkris
« Reply #2 on: Wednesday,November 18, 2020, 11:50:02 AM »
With some difficulty, but  -  button head screw and epoxy resin.
« Reply #3 on: Wednesday,November 18, 2020, 11:56:55 AM »
There, that shows how short sighted I can be! The answer was simpler than I considered!
