Author Topic: Modified Stromberg intake ports?  (Read 1130 times)
Offline Broadside
    • Midland Race and Rally
Re: Modified Stromberg intake ports?
« Reply #15 on: Monday,November 16, 2020, 11:56:50 AM »
I would have thought you should be able to see if it's 'as cast' or been subsequently ground/modified by the surface finish??
« Reply #16 on: Monday,November 16, 2020, 02:13:58 PM »
CW, wouldn't it appear that way in both directions?
I will look closer when I get a chance to see if they are as "cast".
Offline SENC
« Reply #17 on: Monday,November 16, 2020, 03:51:21 PM »
I have a spare for my Elan - a quick measurement was a hair under 47mm both vertically and horizontally, and the gasket ID is round.
Offline Lotuswins
« Reply #18 on: Tuesday,November 17, 2020, 11:06:07 AM »
I would guess they were correcting for a casting flaw.  Note how the stud holes are offset also compared to the outer part of the flange but centered on the modified holes.   Not uncommon, my buddy had a Stromberg head that the front part, ahead of the timing gears, was bent inward significantly but they drilled the front, small bolt heads in it and it worked, just barely.   Must have been a 1/4 inch offset.
Jerry Rude
4005R
