Found them!
Weber 45MCHH, basically half of a DCOE and intended to replace Stromberg's.
They are seeing as lot of use on TR6's and similar British cars.
Apparently pretty new to the market, I believe they should be a bolt-on to your head.
Since they are essentially DCOE's and use the same jets, chokes, and venturies, tuning possibilities should be great.
Not as great as a true Weber head but almost certain to be an upgrade from the right angle flow you now have. And NEW, not worn out or "Rebuilt" to unknown quality.
No, I have no affiliation, but I am happy to see a new solution that does not require adding a computer.
EDIT: Hmm, seems the Weber Carb 45 MCHH may have been too good to be true.
I cannot find a current source for them.
They were originally conceived for use on Harley's.
One post I found said that Spain/Weber were in financial difficulty so some products were suspended.
Might be worth more research.
