Lots more study to do before I commence laminating.
So far it seems I should only cut the outside perimeter, glove box opening, and glove box door before glueing.
The door gets set into the opening during lamination.
I will be using a vacuum bag for clamping, and Unibond 800 Urea glue.
To avoid edge chipping from the router I will need a very good bond.
Fortunately I believe nearly every edge gets a trim piece of some sort by the time it is all assembled. The exception seems to the rocker switches.
