Lotus seems to be taking a holiday while I wait for the cylinder head to be completed. Might be Christmas, but I do hope this year.
Going to try to get back onto the body soon but at the moment all my time is going into putting up the used two-post lift I bought.
Most service work for these requires pulling them down and apart, so I am doing all I can before putting it up.
Looks like I also have to throw my Morris Minor PU together ASAP, even an undersize truck will be better than the current none.
It will be getting the Kent 1600 and a T9 box, along with MGB suspension.
Yah, that will simplify assembly.
But it will get me big brakes, a much stronger diff, and wire wheels.
Around 100 HP and OD should make it very practical to drive.
Even when the Europa is finished the Morris will be the daily driver, particularly in winter.
Had hoped to focus on the El Camino, but the engine I am building is NOT a DD type and there is a lot of fabrication to do for the Jag IRS.
MM is the only really practical car I will have.
