Behind schedule as always.
There is an old saying about perfectionism.
I have got this as good as is reasonably possible without information and tooling that is not really available.
One delay was that I had to space the chassis about 1/4" above the table to align the frame head properly.
The bottom of the head is not flat, there are also weld beads that push it up off the table when it is tilted to 3º.
I abused some machining parallels to jig it all up.
Finally just about ready to weld, Cleco fasteners so that I do not have to work so hard aligning it again.
I did touch up the POR-15 inside the chassis where it burned off from welding.
I am a believer in plug welds and have added a few to the new flanges.
This way it will not just be an edge holding the head in place.
I have cut and fit the top reinforcement piece and made a couple of small dressing plates.
