Having made noise about my shed I decided to put it to the test.
Small propane ceramic heater gets it to near 60º F, a bit less once the sun goes down.
Small task, hmm, let's get a look at the carbs!
They look to have been in excellent shape prior to the car sitting for several years.
Now they have dark brown 'Fuel Varnish' in the bottoms.
I need to figure out if these use the leather shaft seals or not.
From the numbers they are probably original to an Alfa Romeo Spider.
Made a list of my jets and chokes.
Chokes 33, Aux Venturi 4.5, main jet 105, emulsion tube F15.
For the most part my jetting appears to be 'In range' but a 135 main jet and 4.0 auxiliary venturi would be more typical for a 400cc per cylinder (Now 1595cc) engine.
Billings MT where my car came from is 3,373' above sea level.
On checking my home is 4,377' and in a valley so to go anywhere I may frequently climb to around 5,000'.
Of course if I ever wanted to get to CA some of the passes are 14,000'!
Nice that Webers let you change most jets at the side of the road.
Maybe I will replace the ash-tray with an altimeter.
So I have increased displacement a little, compression as well, and another 1,000' of elevation.
More displacement needs more fuel, higher compression wants more fuel, higher altitude richen's mixture.
These should be a cinch to configure!
I also found time to mark the mis-match between my intake manifolds and the head ports.
Plan is to 'Match' them.
But I found a WTH? issue there as well.
I am completely baffled as to why anyone would cut down one intake mounting ear.
They did add another mounting bolt hole but there is no matching hole in the head.
It seems I will be looking for new Weber mounting seals too.
Of course these are not the common sort as used for TC's.
It appears the Payen head gasket set I have is for a wedge engine.
Anyone need it?
And finally, I find myself a little concerned that I will be trying to run-in a fresh engine with carbs that have not been fully sorted in advance.
Pics below include the functional but too ugly to use trailing arm.
