Made it to the hardware store today.
They have a very sparse selection of stains.
I picked one that looked just a fraction darker than original.
Doing a small sample it appears a little lighter than I had hoped but may be OK once I get the clear varnish on it.
Still not sure what type of veneer I have but it has some almost iridescent qualities when viewed at an angle.
I intend to avoid the thick varnish of the original dash.
Semi-gloss Spar Varnish, not gloss.
I will have to match grain at the center but after all the cut-outs there will be very little remaining joint visible.
Hoping to do this soon as it's a relatively simple and inexpensive task.
Using the $12.00 in 'scrap' veneer helps a lot.
Should have a sample pic in the morning after the second coat of varnish.
