Author Topic: these are my rear springs  (Read 497 times)
Offline aspares
« on: Sunday,October 25, 2020, 12:06:29 PM »
I assume they are not original, but can they be adjusted to lower the car? I am hoping to lower the back a couple of inches as well as the front. Any suggestions?
Thanks,
Martin
Re: these are my rear springs
« Reply #1 on: Sunday,October 25, 2020, 12:19:27 PM »
That "castellated" ring around the shock at the bottom of the spring is your adjustable perch. Screw that down to lower the car.
Dave Bean, r.d., and lotus-supplies have "uprated" springs that are stiffer and a bit shorter to give better handling. You might consider them at some point.
« Reply #2 on: Sunday,October 25, 2020, 12:52:44 PM »
Repeatedly spray those adjusters with penetrating oil and let them soak for a few days before trying to turn them.
