Author Topic: Europa TCST  (Read 130151 times)
« Reply #1140 on: Monday,March 10, 2025, 01:12:45 PM »
Going through the dash wiring harness so I can install dash. Since my screws holding the electrical components diminished in size with rust and the dash delaminated, most of the electrical components screwed to back of the dash (washer pump, voltage stabilizer, buzzers etc.) were just hanging there. I have no real idea where they go.
I looked for a pic in the manual but didn’t see one…is there one somewhere  :confused:
Heater switch wouldn’t move due to rusty rocker switch pivot , got it apart and moving …
« Reply #1141 on: Monday,March 10, 2025, 01:29:11 PM »
The washer pump is screwed to the bottom part of the dash (that is covered up by the console) on the driver's side. The flashers are mounted to the left of the washer pump so the washer pump is toward the center. I think the voltage stabilizer is screwed under the last gauge next to the glove box. I threw my buzzers away so I don't remember where they go but as I remember, one of them was hanging from the tach or speedo...
That's generally where they go. You'll have to see exactly where there's room.
« Reply #1142 on: Monday,March 10, 2025, 01:32:30 PM »
Thanks BDA!  So the washer pump is on the front side of the dash?  I sat on the passenger seat “sensor” most of the day ….it’s not comfortable and getting removed!
« Reply #1143 on: Monday,March 10, 2025, 02:08:22 PM »
The washer pump is behind the dash when sitting in the seat. Same with the flashers. Sorry, I wasn’t clear!
« Last Edit: Monday,March 10, 2025, 02:36:27 PM by BDA »
« Reply #1144 on: Monday,March 10, 2025, 04:22:15 PM »
Got it!
Offline Fotog
  • 72 Twin Cam
« Reply #1145 on: Wednesday,March 12, 2025, 09:59:14 AM »
If you don't have an owner's manual, I suggest that it can be useful toward knowing what goes where on the dash.  It doesn't show the back side, but still.... useful to know what's on the 'front' side.
They're here: http://www.lotus-europa.com/manuals/tcowner/index.htm
« Reply #1146 on: Monday,March 17, 2025, 12:57:01 PM »
Finished cleaning dash electrical connections… now in DB10 removal and reinstallation hell ….
« Reply #1147 on: Monday,March 31, 2025, 06:43:31 PM »
DB10 back in, made a couple of jumper wires and tested the windshield wiper motor and mechanism with my battery charger and they move smoothly so I’m not fooling with them. Removed the hood/bonnet/frunk latch seal as the screws were quite rusty, removed the wiper spray nozzles and cleaned them in the ultrasonic cleaner and some other misc. stuff.
« Reply #1148 on: Tuesday,April 01, 2025, 12:22:18 PM »
After looking at the EV discussion made me think …. I have wanted build a BEC (bike engined car) for quite some time …. got a really light weight car and CBR1000R engine …. Hmmmmm
Thoughts?
« Reply #1149 on: Today at 03:55:25 AM »
I wasn’t serious about the bike engine in my Europa as it was April Fools Day yesterday
It may go in the back of this one day …..
« Last Edit: Today at 04:46:00 AM by TurboFource »
« Reply #1150 on: Today at 06:13:31 AM »
Is that a Festiva? Do you know about the Festiva Shogun?
« Reply #1151 on: Today at 07:44:54 AM »
Turbo, I didn't realize you were April fooling. Motorcycle motors have become very popular in club racing and there is an outfit that was selling (sold?) a GSX-R powered Europa (https://www.rcnmag.com/fresh-finds/gsxr-powered-lotus-europa). I would note that in the article, the seller "estimates that the swap probably took 550-560 pounds off the Europa, now weighing in at just 1,219 pounds" is ridiculous since the stock S2 is in the 1300 - 1400 lb range to begin with. So the real weight savings are more modest than he thought.
In fact there is an old thread on it here (https://www.lotuseuropa.org/LotusForum/index.php?topic=3436.0).
« Reply #1152 on: Today at 11:53:28 AM »
It is a Festiva and I know of the Shogun ;)
