Author Topic: Europa TCST  (Read 130854 times)
« Reply #1125 on: Tuesday,February 25, 2025, 07:36:18 AM »
I appreciate the offer, Kram.
I’m anxious to see how your car is coming!
« Reply #1126 on: Wednesday,February 26, 2025, 07:37:56 AM »
  Turbo,
 Vents, I just left mine all black.
Did the same with 693R.  Used 2000 grit to polish the plastic, no one ever noticed, and it looked fine.  Probably would have lost a couple points at a LOG, but since I don't do LOGs it was never an issue.
« Reply #1127 on: Sunday,March 02, 2025, 11:18:32 AM »
Progressing …..
Where does the bracket that holds the odometer reset cable screw to?
« Reply #1128 on: Sunday,March 02, 2025, 11:27:48 AM »
Gauge sun shields I sketched and my son 3D printed to give various gauges same OD and depth….
« Reply #1129 on: Sunday,March 02, 2025, 11:37:22 AM »
Progressing …..
:beerchug:
It's screwed into the back of the dash about 1/2 way between the steering column and the headlight switch. You may want to screw it in after you get the dash installed or till you're sure it's in a good place.
« Reply #1130 on: Sunday,March 02, 2025, 12:10:14 PM »
Sounds like a good idea BDA
« Reply #1131 on: Monday,March 03, 2025, 11:30:37 AM »
Eyeball vent fun …. Inner part of vent stands proud of the body so … hole to the rescue ???
I tried the lathe Kram but the  chuck was too small and I had to grab the metal part and it doesn’t run true with the eyeball.
« Last Edit: Monday,March 03, 2025, 11:58:03 AM by TurboFource »
« Reply #1132 on: Monday,March 03, 2025, 12:31:58 PM »
My wife thinks I have OCD  :confused:
Offline Fotog
  • 72 Twin Cam
« Reply #1133 on: Monday,March 03, 2025, 01:55:34 PM »
It does seem like you're not in any hurry to drive that car.   :)
« Reply #1134 on: Monday,March 03, 2025, 06:00:41 PM »
Fotog, I actually am but ….. I think I am letting “perfection” get in the way of completion!
Offline kram350kram
« Reply #1135 on: Monday,March 03, 2025, 06:01:33 PM »
I might have had my vents apart when I did ? There is always fineline tape to mask and then brush. OCD is what makes the difference between the great and the also runs!
« Reply #1136 on: Tuesday,March 04, 2025, 05:18:19 AM »
Well....favorite saying: "Don't let the perfect become the enemy of the good".  Maybe I should follow that more often...but, sometimes the journey becomes more important than the destination.
Offline Fotog
  • 72 Twin Cam
« Reply #1137 on: Tuesday,March 04, 2025, 11:02:20 AM »
I can understand.
I'd really like to perfect... er.... improve my car.  But the driving gets in the way.   :)
I worry for you that with the turbo and all, you might have some things to sort out before you can really use it.
« Reply #1138 on: Tuesday,March 04, 2025, 12:03:09 PM »
Hopefully with the AFR wideband gauge, programmable ignition and programmable water/methanol injection it won’t take too long!
« Reply #1139 on: Tuesday,March 04, 2025, 12:36:44 PM »
  Take as long as you want.
 Mods take time and you want to have it as perfect as possible is understandable.
Keep moving forward, jump around with items so you don’t stall out the build.
Dman
