Author Topic: Europa TCST  (Read 133110 times)
Online TurboFource
« Reply #1095 on: Thursday,December 26, 2024, 06:33:11 AM »
I drew these gauge sun shields to make my various gauges the same “OD” and and “depth” so they would blend in together better. My son printed them out for Christmas for me on his Bambu Lab 3D printer.
« Last Edit: Thursday,December 26, 2024, 06:40:38 AM by TurboFource »
Online TurboFource
« Reply #1096 on: Wednesday,January 01, 2025, 11:34:33 AM »
Removed the oil pressure and water temp gauges from the wiring harness. Of course the knurled thumb nuts were rusted tight and would nut come loose even after soaking with penetrating oil. I resorted to heat using my jewelers torch to just heat the nuts then reapplying penetrating oil and then repeat a couple of times. This is usually effective and worked this time :)
How can I bench check the temp gauge?
Still trying to decide if I want to take the glass off the gauges for further detailing ….
« Last Edit: Wednesday,January 01, 2025, 11:36:42 AM by TurboFource »
« Reply #1097 on: Wednesday,January 01, 2025, 04:04:08 PM »
  Bench testing the temp gauge and sender is in the electrical portion of the manual.
   https://lotuseuropa.org/images/WorkshopManual/S2_Section_M_-_Electrical_Equipment.pdf
  Section m page 47
  Btw , thanks for the tip in the shims.
« Reply #1098 on: Wednesday,January 01, 2025, 05:02:57 PM »
There is a good write up on electrical gauges here (http://lotus-europa.com/manuals/misc/electrical/gauges.html) and here (http://lotus-europa.com/manuals/misc/electrical/meterinfo.html) which is from a link on the first page.
Online TurboFource
« Reply #1099 on: Thursday,January 02, 2025, 12:29:43 PM »
On the subject of gauges, I have a tach question. It seems someone posted the tach needs modded to work with the 123ignition?
I found this online as a different solution:
https://www.123ignitionshop.com/gb/faqs/faq_technische_vragen/tachometer-123ignition.html?srsltid=AfmBOoqsxZhFepzXS3agpAsnAzEmKxjugvwnHDPvMboXG-02cpBid6il
Can someone with an electrical background give their input?
Offline RonPNW
  • S2 54/1678
« Reply #1100 on: Friday,January 03, 2025, 01:46:10 PM »
I did this.
https://www.lotuseuropa.org/LotusForum/index.php?topic=4570.msg49596#msg49596
I have heard there is a commercial equivalent but do not know anything about it.
Ron
Online TurboFource
« Reply #1101 on: Sunday,January 05, 2025, 12:24:03 PM »
I decided to take the glass off the gauges to clean them and to paint the rusty trim pieces in the tach and speedo.
I first tested the temp and fuel level gauges by just using my 6 volt trickle charger and they both moved so they should be good. I already know the tach and oil pressure gauge work from first run. I will check the speedo with my drill.
The small gauges were much more challenging to get apart than the tach and speedo! I removed the gauge to dash gasket with an exacto blade. I then carefully worried the bezel loose with a flat blade screwdriver, I also applied WD40 to bezel gaps on the small gauges with a model paint brush. I bought a strap wrench but it was useless and used a work glove with a grippy material on it to get the bezels loose. On the small gauges the original bezel to glass sealant turned into some kind of mystery gritty material  :confused:
Now to clean, touch up, paint and reassemble…..
« Last Edit: Sunday,January 05, 2025, 12:32:19 PM by TurboFource »
Online TurboFource
« Reply #1102 on: Sunday,January 05, 2025, 01:16:10 PM »
Just verified with a drill that speedo, odometer and trip meter work  :)
Online TurboFource
« Reply #1103 on: Tuesday,January 07, 2025, 01:00:29 PM »
Getting lost in the details again …. everything touched up and ready for reassembly after everything has dried completely. Minor wrinkle finish applied to inner speedo and tach bezels by spraying light coats of wrinkle paint (to cover minor rust pitting).
« Reply #1104 on: Tuesday,January 07, 2025, 01:18:41 PM »
Nice!  :beerchug:
« Reply #1105 on: Tuesday,January 07, 2025, 02:49:42 PM »
  Looking great.  :trophy:
 Getting the oil gauge and the sender working in sync was the problem for me. I see you got that covered.
Online TurboFource
« Reply #1106 on: Wednesday,January 08, 2025, 01:57:29 PM »
Together …. made new seals/gaskets out of window screen spline material super glued into an o -ring (saw this on a Triumph forum) instead of using sealant, their only purpose is to keep the glass from rattling really, as the gauges are open in other areas …..
« Last Edit: Thursday,January 09, 2025, 03:22:52 AM by TurboFource »
Offline cwtech
« Reply #1107 on: Wednesday,January 08, 2025, 03:35:25 PM »
VERY nice work, Sir!
Online TurboFource
« Reply #1108 on: Wednesday,January 08, 2025, 03:46:18 PM »
Thanks CW!
« Reply #1109 on: Wednesday,January 08, 2025, 06:00:00 PM »
Nice, thanks for the spline tip.
