Author Topic: Europa TCST  (Read 133187 times)
« Reply #930 on: Saturday,March 16, 2024, 04:10:54 AM »
Still working on wiring, made short adapter wires for new fan and temp sensor since they have different connections than the original otter switch  etc. I was going to pull the gauges out of the dash but on some of them the stud just spins in the gauge  >:(   I don’t really want to pull the dash yet …. Found the VIN number on the rear bulkhead/firewall also. Painted around radiator opening so I can install it and not have to pull it out to paint the  forward compartment.
« Reply #931 on: Saturday,March 16, 2024, 07:29:04 AM »
Are you fitting a relay to power the fan triggered by the temperature sensor?
Apologies if you are already aware - you might have mentioned it and this is a long thread..... The original otter switches could handle the current to power the fan, but more modern sensors are only intended to handle the current to power a relay, with the relay handling the current delivery.
« Reply #932 on: Saturday,March 16, 2024, 07:55:20 AM »
SilverBeast,
I am aware of the possible need for a relay but have not gotten that far yet,
I need to research the rating of the new temp switch. Thanks for the reminder ;)
« Reply #933 on: Monday,March 18, 2024, 12:57:55 PM »
Test fit …. Being “thrifty”, I will  try the fan that came with the radiator realizing I will probably have to upgrade it  (many parts etc. ahead that still need purchased). Of course the holes didn’t quite line up etc…fan is sealed to the radiator so all the air goes through it .
« Reply #934 on: Monday,March 18, 2024, 02:48:12 PM »
I also wouldn't risk current through a temp switch. it can take it but relays can designed to do it. If you want reliable without worry later.
« Reply #935 on: Monday,March 18, 2024, 06:12:48 PM »
Planning on getting a relay tomorrow  ;)
« Reply #936 on: Monday,March 25, 2024, 12:43:03 PM »
A Spring like 47 degrees in the garage this morning ….  :-\
Cleaned and painted the “frunk” on Saturday and my back is still complaining…  :o ...cleaned up front wiring harness today and installed relay for the fan.
« Last Edit: Monday,March 25, 2024, 12:44:40 PM by TurboFource »
« Reply #937 on: Monday,March 25, 2024, 01:19:19 PM »
I forgot to mention my 51 year old Tudor washer fluid bag doesn’t leak!
« Reply #938 on: Monday,March 25, 2024, 01:49:24 PM »
Make sure you clean out your washer bag! I didn't realize mine had junk in it and I clogged up my washer pump. Thinking I had a bad pump I tried to take it out but couldn't get to it so I replaced the whole thing with a washer tank with its own pump.
« Reply #939 on: Monday,March 25, 2024, 01:51:32 PM »
Already did BDA !
« Reply #940 on: Monday,April 01, 2024, 12:33:44 PM »
Hanging out under the dash today ….  :help: Speedo cable, oil pressure gauge line and pedals installed.
« Reply #941 on: Monday,April 01, 2024, 12:36:13 PM »
Ahhh! The Lotus position!  :pirate:
« Reply #942 on: Monday,April 01, 2024, 01:34:05 PM »
Mine had carpet behind the pedals. Are you leaving it painted but uncarpeted?
« Reply #943 on: Monday,April 01, 2024, 01:54:47 PM »
Not sure at this point Kendo …. Just want to drive it ….
« Reply #944 on: Monday,April 01, 2024, 04:48:44 PM »
There is that!
