Author Topic: Europa TCST  (Read 133159 times)
« Reply #870 on: Monday,September 18, 2023, 12:41:17 PM »
Installed needle bearings on throttle shaft, turbo torn apart in ultrasonic cleaner before rebuild, and a shiny new distributor showed up today 8)
« Reply #871 on: Monday,September 18, 2023, 01:03:47 PM »
Change your needle jets while you are in there.
« Reply #872 on: Monday,September 18, 2023, 06:58:48 PM »
Will do JB, didn’t you say to plug up the compensator etc?
« Reply #873 on: Monday,September 18, 2023, 09:01:46 PM »
Yes, if the temp compensator “needle” is in good shape, just use the adjusting screw to shut it tight.  The decell valves I block off using a gasket with no passages.
« Reply #874 on: Monday,September 25, 2023, 12:25:16 PM »
Carb together.... Bought a B2AR needle and realized I have new one from 50 years ago from CW Tech... Interesting the new one seems to be brass and the old one stainless ... running the vintage one ; Did some cleaning on turbo housings... Before pic of carb for comparisons sake
Followed JB's suggestions too 8)
« Last Edit: Monday,September 25, 2023, 12:28:20 PM by TurboFource »
« Reply #875 on: Monday,September 25, 2023, 02:29:03 PM »
I don't have Strombergs but I'd say your carb looks better now...  :)
« Reply #876 on: Saturday,September 30, 2023, 01:46:38 PM »
Turbo cleaned up...bearing cartridge together with billet compressor wheel, new turbine shaft etc.
« Reply #877 on: Tuesday,October 03, 2023, 02:26:45 PM »
Turbo together and back on motor....need to figure out exhaust and all the little things like cable hookups etc.....
« Reply #878 on: Tuesday,October 03, 2023, 07:43:00 PM »
 :beerchug:
« Reply #879 on: Tuesday,October 10, 2023, 06:19:23 PM »
Went to mount my small alternator because the original was ugly and heavy, only to discover the vertical faces for the stock alternator mount were machined by a blind person using an angle grinder as they weren't square to anything useful to me  :o
Then I thought about making a new mount ... And then "simplify...then add lightness" entered my thought process and I decided to use one of the bell housing bolts and a spacer from the hardware store 8)
Trying to figure out the exhaust as I am seriously constrained by the radius of the mandrel bends ....  first effort will not let me use the luggage bin... I will search for tighter radius bends for my "touring" exhaust that will allow luggage bin usage  ;)
« Last Edit: Tuesday,October 10, 2023, 06:33:46 PM by TurboFource »
« Reply #880 on: Tuesday,October 10, 2023, 08:03:04 PM »
Neato, Turbo.
Never thought this before, but does an alternator care which way it rotates?
A quick search seems to indicate "no" but to be mindful of the fan direction . . and then I note your alternator doesn't seem to have a fan!
On the tighter radius bends, I seem to remember people offering 'donuts' which you cut up as needed. Looking at the pic, they appear to be formed from sheet steel (as far as I know) and are tighter than a fishes.
https://www.ebay.com.au/itm/165836247562
« Reply #881 on: Wednesday,October 11, 2023, 03:35:58 AM »
The way they are mounted on a Twin Cam the alternator turns the same direction as if it were at the front of the motor since it hasn’t been flipped around.
I have seen those “donuts” before, thanks for the reminder Gavin.
« Reply #882 on: Wednesday,October 11, 2023, 07:44:39 AM »
Alternators can turn either way.  The fan still works but it will flow air in the opposite direction.  This is usually not a problem.  The only exception being if the alternator has ducted cooling air.  Not an issue in this case.
This alternator has a built in fan inside the body.
« Reply #883 on: Wednesday,October 11, 2023, 01:48:12 PM »
$4 belt tensioner....revised "touring" exhaust allowing luggage bin use  :)
« Reply #884 on: Monday,October 16, 2023, 01:37:01 PM »
Exhaust welded with O2 sensor bung and support brace bracket. Brace made. Festiva throttle cable pulley/disc/lever(?) fits a Stromberg with very minimal modification. Need to make a custom throttle cable and bracket. Exhaust will exit by taillight...new turbo system and exhaust is 40.8 lbs lighter than original system :)
