Author Topic: Europa TCST  (Read 131387 times)
« Reply #780 on: Monday,February 27, 2023, 12:48:28 PM »
I will have to order one Bryan!
You will not be disappointed.  Went from an empty/old fluid system to a full flush and bleed in less than half an hour.
« Reply #781 on: Monday,February 27, 2023, 12:52:32 PM »
I second the Eezi Bleed. Wroks great. (Though it's weird using a tire as the compressed air source: great bled brakes, one flat tire :))
« Reply #782 on: Monday,February 27, 2023, 02:01:36 PM »
I used mine last year on the Europa. I bought it in 1986/87 to use on my mini!
« Reply #783 on: Thursday,March 02, 2023, 12:29:37 PM »
"Things from above" (since body is hanging from ceiling) started today (since I basically now have a rolling chassis).  :trophy:
Removed my iron oxide ravaged clutch cable.
Removed fuel tanks and only broke
one bolt off! Critter debris and lots of rot in left tank, right tank looks pretty clean inside and salvageable.
I may relocate sending unit to right side tank and run one tank to get it going....would
lose 10lbs of weight and offset drivers weight too....
Interesting that the bottom of the tanks are stainless....
« Last Edit: Thursday,March 02, 2023, 03:34:21 PM by TurboFource »
« Reply #784 on: Thursday,March 02, 2023, 02:11:30 PM »
The bottoms are stainless!?
Might it be time for aluminum tanks a la TurboForce?
Offline cwtech
« Reply #785 on: Thursday,March 02, 2023, 02:40:06 PM »
I didn't remember them being stainless, but I can't argue with that.    :headbanger:
I remember the driver's side tank leaking and a new bottom was installed by someone (not me).  ...I don't think that one was stainless. ...The new bottom was totally smooth and it would "oil-can" loudly.   ...I believe the original tank bottoms had beads rolled in them to prevent flexing.
C.R.A.F.T. strikes again because I can't remember when or by whom the stainless bottoms were put on.
« Reply #786 on: Thursday,March 02, 2023, 03:22:55 PM »
CW - both bottoms are stainless.
BDA - aluminum when either time or financial budget allows it ... would probably fabricate my own... time to get this thing going!
« Reply #787 on: Thursday,March 02, 2023, 08:06:00 PM »
That’s what I meant by “a la TurboForce.” I’m sure you could make tanks as good or better than any for sale and for a lot less.  :welder:
« Reply #788 on: Monday,March 06, 2023, 12:22:48 PM »
Repaired fuel level sending unit (it wouldn't move), moved sending unit to passenger tank,
upgraded tank fuel line to 3/8" stainless and extended it to rear of tank.
Ordered gear reduction starter, clutch cable, oil pressure  gauge line and misc items.
« Reply #789 on: Tuesday,March 07, 2023, 06:04:12 PM »
Some goodies showed up today 8)
The gear reduction starter is 3.6lbs lighter than the original  :)
« Reply #790 on: Tuesday,March 07, 2023, 06:24:13 PM »
Yeah, your new starter is lighter than the stock one but you could have had my lightly used stock starter that was OEM on my TCS for only $25 + shipping!  :). (http://www.lotuseuropa.org/LotusForum/index.php?topic=5760.0)
Of course the reason mine is for sale is because I replaced it with a gear reduction starter of my own!  ;D
« Last Edit: Tuesday,March 07, 2023, 07:28:37 PM by BDA »
« Reply #791 on: Wednesday,March 08, 2023, 03:33:10 AM »
Lighter starter = lighter wallet
« Reply #792 on: Saturday,March 11, 2023, 12:05:37 PM »
Painting tank... While waiting for paint to dry....
Installed gear reduction starter to make sure it clears turbo up pipe .... It does  8)
Because I am a pack rat, the next challenge is to turn my stash of rod ends, end links etc. into
a DIY cable shifter.
« Reply #793 on: Sunday,March 12, 2023, 09:24:35 AM »
You got that right.  The lightest parts usually cost the most...
« Reply #794 on: Sunday,March 12, 2023, 09:27:36 AM »
May be obvious...but hope you wrap that section of the pipe...or a blanket on the starter (just to keep the radiant heat from having an effect on the winding insulation, etc.  I'd go for the blanket...;)
