Author Topic: Europa TCST  (Read 131367 times)
« Reply #765 on: Saturday,February 11, 2023, 05:27:23 PM »
  No .. probably much better for larger feet.
 I only drove literary madness’s car, without shoes, which reminds me to buy a pair of sand shoes our drivers shoes . I have a 10 1/2 eee foot . That’s why I mentioned an adjustable sections on the shaft.
« Reply #766 on: Saturday,February 11, 2023, 05:50:21 PM »
You can give yourself some extra right foot room by shaving off the right and/or left side of the brake pedal pad and more space by shaving off 1/8” to 1/4” from the pedal itself. You should be able to get your 10 1/2 EEE foot on either the gas or brake or both.
« Reply #767 on: Saturday,February 11, 2023, 06:02:26 PM »
  Thanks BDA,  copying and pasting that to a “to-do list.”
Offline cwtech
« Reply #768 on: Saturday,February 11, 2023, 08:12:15 PM »
  The pedals definitely look good.
  I see too that they the TCs' jog outward more than an S2s'.
When I bought the Europa, which is now TurboFource's, the dealer bent the clutch pedal to allow more room for my big feet.
« Reply #769 on: Saturday,February 11, 2023, 08:26:04 PM »
I might try bending the brake pedal first but be careful that it doesn't rub on the steering column.
« Reply #770 on: Saturday,February 18, 2023, 12:11:18 PM »
Got slowed down this week...it took 3 years but all three of us (my son, then wife, then me) tested positive for covid for the first time this week >:( .... day 3 of covid and I managed to finish my pedal assembly and upgraded the clamps I had put on my trailing arm frame bushings...
« Last Edit: Saturday,February 18, 2023, 12:19:13 PM by TurboFource »
« Reply #771 on: Saturday,February 18, 2023, 12:39:05 PM »
Hope you all are coping with the Wuhan flu ok and get over it quickly!
Your pedals look nice. Is the brake pedal meant to be adjustable left to right?
« Reply #772 on: Saturday,February 18, 2023, 12:58:21 PM »
BDA, yes. I want to make sure I am in line with the master cylinder so I am pushing it straight.
« Reply #773 on: Saturday,February 25, 2023, 09:12:36 AM »
Pedals temporarily mounted...hope to bleed brakes this week.... Good thing I made brake pedal adjustable side to side...
Has anyone else made pedals from those drawings :confused:
« Reply #774 on: Saturday,February 25, 2023, 09:51:31 AM »
The pedals still move when they are bolted down too  8)
« Reply #775 on: Saturday,February 25, 2023, 10:47:25 AM »
 :beerchug:  :pirate:
« Reply #776 on: Saturday,February 25, 2023, 12:10:31 PM »
Hope you all recover without incident from the Wuhan flu.  Gone through 2 bouts.  Had all the jabs.  Still got it.  Gave me time to work on things (just as you have) last year whilst self-isolating from society.
Pedals look super.  Nice work!
« Reply #777 on: Monday,February 27, 2023, 11:45:05 AM »
Brakes bled today.....took awhile using gravity/vacuum/manual bleeding (used PVC pipe to push on
pedal while doing the rears). Took several rounds of snugging fittings to sneak up on no leaks. My first time doing brake line flares and happy to say I didn't need to redo any  :)
« Last Edit: Monday,February 27, 2023, 12:06:41 PM by TurboFource »
« Reply #778 on: Monday,February 27, 2023, 11:53:10 AM »
pedal while doing the rears). Took several rounds of snugging fittings till there were no leaks. My first time doing brake line flares and happy to say I didn't need to redo any  :)
great flare tool, guy.
I used the Gunson EEZIBLEED kit when I did mine after excising the boosters and building the jumpers.  Worked a treat; one-person job.  Just a suggestions for the next time.
« Reply #779 on: Monday,February 27, 2023, 12:07:47 PM »
I will have to order one Bryan!
