Author Topic: Europa TCST  (Read 133190 times)
« Reply #645 on: Wednesday,November 09, 2022, 08:59:03 PM »
Usually you can adapt one on hand by using tape wrap to adjust fit.  I have also successfully just lined them up (carefully) by eye.
« Reply #646 on: Thursday,November 10, 2022, 03:30:14 AM »
I will be trying the tape idea today….
« Reply #647 on: Thursday,November 10, 2022, 01:22:36 PM »
1/2" drive extension and tape worked great as clutch alignment tool, thanks JB and the Internet!
Almost bolted in chassis...would have been but I had the motor mounts on the wrong sides ::)
« Reply #648 on: Thursday,November 10, 2022, 01:32:28 PM »
Pretty motor! That's got to feel good!!!
« Reply #649 on: Thursday,November 10, 2022, 02:52:06 PM »
Before....
« Reply #650 on: Thursday,November 10, 2022, 03:01:17 PM »
Big improvement!!
« Reply #651 on: Friday,November 11, 2022, 08:15:27 AM »
In!     :pirate:
Fit much easier with the motor mounts on the correct sides ;)
« Reply #652 on: Friday,November 11, 2022, 08:21:12 AM »
Looks great!
How did the molded motor mounts work? Fit right in?
« Reply #653 on: Friday,November 11, 2022, 10:29:00 AM »
Kendo the motor mounts fit fine, However the right side one is at a slight angle when tightened up just like the original, makes me believe the bracket that bolts to the engine is off slightly. I don’t think it will go anywhere so probably not an issue. With them and the tranny mounts it seems fairly securely located!
Offline cwtech
« Reply #654 on: Friday,November 11, 2022, 12:55:07 PM »
If I remember correctly, the ends of the mounting brackets were at an angle, not perpendicular to their mounting flanges at the engine block.
« Reply #655 on: Friday,November 11, 2022, 07:54:04 PM »
Looking good.
I kinda like the cam cover treatment, too.
Questions:
Do the gearbox mounts feel a bit stiffer?  . . which might be difficult to determine unless compared to a new original one.
What is the spacing of the gearbox mounts – bolt to bolt.
« Reply #656 on: Saturday,November 12, 2022, 03:52:13 AM »
Gavin,
They are definitely stiffer! They are approximately 12-1/8" center to center.
« Reply #657 on: Saturday,November 12, 2022, 09:02:21 AM »
Thanks, Turbo.  :beerchug:
« Reply #658 on: Sunday,November 13, 2022, 01:17:24 PM »
    Turbo,
            Pat yourself on the back. Your work will be preserved for at least another 50 years. These cars are truly a art form in there own right.
       History is important.You made your mark.
« Reply #659 on: Sunday,November 13, 2022, 04:07:34 PM »
Thanks for the kind words DMan!
