Author Topic: Europa TCST  (Read 132809 times)
« Reply #600 on: Monday,August 29, 2022, 01:35:04 PM »
Baked header.
Reclocked turbo exhaust housing 45 degrees.
Modified 90 degree adapter to a 45, which lines up nicely now and will require a simple 90 degree up pipe to turbo :)
Modified v-band adapter wastegate so it would open slightly farther and "unshrouded" it's valve for better flow and to hopefully prevent boost creep....
« Last Edit: Monday,August 29, 2022, 01:56:39 PM by TurboFource »
« Reply #601 on: Friday,September 02, 2022, 12:06:45 PM »
Tacking new up pipe together brought back memories of aircraft welding in the Air Force...laying down and using knee to run foot pedal, right, left, forehand and backhand welding  8)
Pics:
New vs old turbo up pipe
Then new up pipe
Tacking together
« Last Edit: Friday,September 02, 2022, 12:17:08 PM by TurboFource »
« Reply #602 on: Friday,September 02, 2022, 12:25:07 PM »
Nice work!  :beerchug:
I'd say your pipe looks A LOT better than the old one!  :)
Offline 69merc
« Reply #603 on: Friday,September 02, 2022, 12:43:25 PM »
Wow!! :welder: :beerchug:
Amazing work!
« Reply #604 on: Friday,September 02, 2022, 12:45:30 PM »
Used this for backup since I am not setup to run argon backup....not "sanitary grade"
but better than stainless "sugar" on backside of weld...exhaust worthy I think...
« Last Edit: Saturday,September 03, 2022, 07:39:32 AM by TurboFource »
« Reply #605 on: Friday,September 02, 2022, 11:08:31 PM »
Oh, a hitherto aircraft welder, so that explains the very neat and precise joints.
I don't mind saying I'm rather impressed.
This is also some relief for me . . or at least that's how I intend to rationalise the thought that mine will never be that good because I simply have not had the time, practice, training or experience.
Brilliant work, Turbo.
« Reply #606 on: Saturday,September 03, 2022, 07:42:20 AM »
Thanks all.
Gavin I was stationed at Beale AFB....worked on the SR-71, U-2/TR-1, KC-135, T-38
« Reply #607 on: Thursday,September 08, 2022, 05:55:19 PM »
Looks like it will fit  8) ....turbo is above frame rail and within it's outer edge (framing square), I tried to stay within the "real estate" of the original build....started on oil drain (goes where fuel pump was) and figuring out oil supply line and turbo support.
« Last Edit: Friday,September 09, 2022, 12:37:01 PM by TurboFource »
« Reply #608 on: Monday,September 12, 2022, 03:45:06 PM »
Minimal progress this past week....working on a kitchen project....because "happy wife, happy life" ;)
Finished oil drain plate and ran oil supply line.
« Reply #609 on: Monday,September 19, 2022, 06:45:45 PM »
Still working on kitchen project but managed to make a turbo support brace that will bolt to a bell housing bolt. Started carb mounting using a Mikuni carb boot (bolt pattern worked with no mods) so the carb will be rubber mounted to help absorb vibration and possible fueling problems from it...modified boot for vent etc....
« Last Edit: Monday,September 26, 2022, 06:30:49 PM by TurboFource »
« Reply #610 on: Monday,September 19, 2022, 07:30:45 PM »
Cool stuff!!
I hope the kitchen project comes out as well!!
« Reply #611 on: Friday,September 23, 2022, 05:19:49 PM »
-Bead on tube to engage groove in carb boot
-Wood lathe "machining"
-Carb mounted
« Reply #612 on: Friday,September 23, 2022, 06:14:04 PM »
That Stromberg is a bit of a cork in the system.  Why not fit a flat-slide Mikuni?
« Reply #613 on: Friday,September 23, 2022, 07:24:28 PM »
 Great job there turbo, I’m in awe .
« Reply #614 on: Friday,September 23, 2022, 07:35:24 PM »
JB,
The Aussies say the CD-175 will flow enough air draw through for 250hp…we will see. I envision a Mikuni  48mm HSR at some point being installed :) ( if I was a rich man instead of a normal guy trying to get a Lotus on the road I would have already bought one  ;))
« Last Edit: Friday,September 23, 2022, 07:37:43 PM by TurboFource »
