Author Topic: Europa TCST  (Read 133182 times)
« Reply #570 on: Tuesday,July 05, 2022, 05:31:33 AM »
I am fairly certain they seal better than the burnt valve I replaced ;)
« Reply #571 on: Saturday,July 09, 2022, 02:18:38 PM »
Valve springs etc. installed after confirming retainer to guide clearance at full lift.
Ready to bench check intake valve clearance.
« Reply #572 on: Monday,July 11, 2022, 11:07:37 AM »
Hoped to have valve clearance set today but I ran into an issue on the
intake side. My new intake valves are .020” longer that the ones they replaced.
This means I would have to use shims at the low end of the commonly available
 range (.060”) which would make future adjustments difficult. The shims previously installed were in the
.080 - .082” range confirming the length issue. I removed one new valve and compared the length
to 2 different sets of used valves. I used some .045” washers as shims to determine where I am at…..
New valves 3.917”
Removed valves 2.897”
Other used set 3.902”
This kind of stuff eats the time! :-\
« Last Edit: Tuesday,July 12, 2022, 05:20:33 AM by TurboFource »
Offline cwtech
« Reply #573 on: Monday,July 11, 2022, 07:38:49 PM »
Are the grooves for the keepers in a different location than the used valves?
.015" to .018" removed from the end of the valves should get you where you want ???
« Reply #574 on: Tuesday,July 12, 2022, 03:32:47 AM »
That is what I am looking to do CW.
There is plenty of room from the tip of the valve stem to the keepers or retainer.
« Last Edit: Tuesday,July 12, 2022, 05:19:37 AM by TurboFource »
« Reply #575 on: Tuesday,July 12, 2022, 12:29:30 PM »
NAPA machine shop will shorten them for $10-12 each.
I sent an email to Ray at RD Enterprises today about it....
« Reply #576 on: Wednesday,July 13, 2022, 02:32:19 PM »
Still waiting to hear back on valve length from Ray....
Had a couple of hours this morning so I put the head on the block with missing valves so I could start on new turbo system intake....
Yes I know the valve cover looks terrible.....
« Reply #577 on: Sunday,July 24, 2022, 11:10:19 AM »
Shiny object showed up yesterday.....old fan and radiator weighed @27.4lbs...new setup weighs 8.8lbs total.....fan is probably junk as far as airflow...SPAL in the future...
Was out of town last weekend and family get together this weekend....more progress will happen tomorrow....
« Reply #578 on: Sunday,July 24, 2022, 11:29:42 AM »
Now that's shiny!!
« Reply #579 on: Monday,July 25, 2022, 02:10:29 PM »
Worked on new intake for turbo today.....just taped together in pics as I have to add some tubing between the elbows and middle section for proper spacing on the head.
Water cooled .60 trim Garrett T3 with .48 exhaust housing to replace the antique Crane turbo.
« Last Edit: Monday,July 25, 2022, 02:13:42 PM by TurboFource »
« Reply #580 on: Friday,July 29, 2022, 02:18:27 PM »
Got my the valves shortened the .020 to match what came out, $21.86 to have the intakes shortened at local NAPA machine shop and less than one day turn around! Reclocked compressor housing to better suit the turbo's new home ;)
« Reply #581 on: Friday,July 29, 2022, 02:36:09 PM »
Isn't it great when a plan comes together?!  :beerchug:
« Reply #582 on: Monday,August 08, 2022, 01:08:52 PM »
Finished intake flanges and started welding stuff together....
« Last Edit: Monday,August 08, 2022, 01:24:32 PM by TurboFource »
« Reply #583 on: Monday,August 08, 2022, 01:11:20 PM »
Nice welding job!!  :welder:
Offline 69merc
« Reply #584 on: Tuesday,August 09, 2022, 06:38:52 AM »
I concur!  Nice  :welder:  :trophy:
I’m closely following your turbo journey (maybe turbo mine in the near future).
