Author Topic: Europa TCST  (Read 133151 times)
« Reply #525 on: Wednesday,April 20, 2022, 11:23:33 AM »
Planning on gray ......
« Reply #526 on: Wednesday,April 20, 2022, 04:04:34 PM »
 8)
« Reply #527 on: Wednesday,April 20, 2022, 05:04:10 PM »
Pretty!  :beerchug:
« Reply #528 on: Friday,April 22, 2022, 08:55:45 AM »
Ooooo... purdy.  8)
« Reply #529 on: Sunday,April 24, 2022, 12:39:28 PM »
Chevy orange now gone, head painted today and hopefully the block tomorrow.
« Reply #530 on: Sunday,April 24, 2022, 01:20:47 PM »
I'm at the same stage with my block and head though mine only has the machine shop work residue to clean off. What method did you use to clean the head/block surface and did you use a primer? My block will also be some shade of grey.
« Reply #531 on: Sunday,April 24, 2022, 01:53:58 PM »
Joji,
I scrubbed it with a Scotchbrite pad and Simple Green and then hosed it off.
Let it dry and cleaned with alcohol in a spray bottle. I am using Dupli-Color with ceramic
engine paint, it does not say to use primer. It said it’s for manifolds etc… I will be trying to duplicate the Lotus gray since it has a blue tinge to it…..hope to try that tomorrow and will post results…
« Last Edit: Sunday,April 24, 2022, 01:56:25 PM by TurboFource »
« Reply #532 on: Sunday,April 24, 2022, 05:19:22 PM »
Lotus engine grey is Ford engine grey.
« Reply #533 on: Monday,April 25, 2022, 01:12:02 PM »
Painted first coat on block today (just went with Smoke Gray since I already had it), baked paint on head since my wife was at work today
and I wasn't.... ::)
Amazing how much better things look with a coat of paint!
« Last Edit: Monday,April 25, 2022, 01:21:25 PM by TurboFource »
« Reply #534 on: Monday,May 02, 2022, 04:29:36 PM »
More parts cleaned and painted, finished painting block, cylinders honed and threaded holes in block have all been chased....
« Reply #535 on: Monday,May 09, 2022, 04:42:25 PM »
Rings hand filed to fit and deburred. Epoxy repairs to some pits in the timing cover
and painted.
Hope to start engine assembly next week....
« Last Edit: Monday,May 09, 2022, 04:44:16 PM by TurboFource »
« Reply #536 on: Monday,May 09, 2022, 06:39:11 PM »
Great stuff, Turbo! More fun ahead!
« Reply #537 on: Thursday,May 12, 2022, 04:44:23 AM »
997, 998, 999…..1000!
A thousand posts and still having fun 8)
« Reply #538 on: Saturday,May 14, 2022, 04:38:23 PM »
Removed the last of the Chevy orange paint off the high volume oil pump, and water pump pulleys.
Crank in block and caps torqued...spins nicely.
Rings on pistons, Pistons on rods.
Challenged by Literary today to drive it around the block in 6 months......
« Last Edit: Saturday,May 14, 2022, 04:40:01 PM by TurboFource »
« Reply #539 on: Saturday,May 14, 2022, 04:55:59 PM »
Moving right along…
Ok! Six months! We’ll be expecting your report!
