Author Topic: Europa TCST  (Read 133149 times)
« Reply #165 on: Thursday,February 25, 2021, 04:35:51 PM »
Before and after (same carb).
Future mods.....thin throttle shaft and install needle bearings for it to pivot in.
Been thinking about going to a blow through setup.....
« Reply #166 on: Thursday,February 25, 2021, 04:54:36 PM »
On seeing the first pic, I'd have written it off.
But that's quite a transformation, Turbo . . . well done.
« Reply #167 on: Thursday,February 25, 2021, 05:00:48 PM »
Amazing transformation!!  You’re a miracle worker!!  :beerchug:
« Reply #168 on: Thursday,February 25, 2021, 08:25:00 PM »
New throttle shafts and shaft bushings are available.  Done lots and lots of them.  Change the needle jet as well as the needle.
« Reply #169 on: Saturday,February 27, 2021, 01:06:12 PM »
Lift off has started 8).       My goal was to have body off chassis by end of February......I think I might make it.
« Reply #170 on: Saturday,February 27, 2021, 01:23:40 PM »
Being on time is a good thing! Congratulations on your lift-off!!  :beerchug:
« Reply #171 on: Sunday,February 28, 2021, 01:09:57 PM »
Today's progress......made my goal of body off by end of February :trophy:
I am the in the middle of the one pic with my two sons :)
The block and tackles were workable but next time I will buy winches! Probably add some more bracing to the supports....the block and tackles are still attached but I didn't want to tempt Murphy to show up so I figured I had better support it also.
The top of the chassis has no surprises! So I will be repairing the bottom of the T-section, and refurbishing chassis and running gear....
« Last Edit: Sunday,February 28, 2021, 01:15:57 PM by TurboFource »
« Reply #172 on: Sunday,February 28, 2021, 01:36:46 PM »
Nice family, Turbo! No surprises on the top of your frame is nice but that's where the least surprises are. As you noticed, the bottom of the the 'T' and and the corners of the 'T' and the backbone.
I think I suggested to you earlier but in case I didn't, now is a great time to make better access to your steering u-joint.
« Reply #173 on: Sunday,February 28, 2021, 01:39:34 PM »
You did mention that BDA, and I will 😊
« Reply #174 on: Sunday,February 28, 2021, 03:35:48 PM »
 Congrats Turbo! Now the fun begins  :beerchug:
« Reply #175 on: Monday,March 01, 2021, 12:02:37 PM »
Today I just tried to reorganize work space after shuffling everything around to lift body. Also sprayed penetrant on all the hardware I could see.
Pics -
Space  :)
More critter debris ....this one must have to wanted to be a mechanic because he had a wrench in there with him :o
« Last Edit: Monday,March 01, 2021, 12:04:22 PM by TurboFource »
« Reply #176 on: Monday,March 01, 2021, 05:17:34 PM »
More critter debris, Turbo?
In Oz, we pride ourselves on our critters . . particularly the deadly ones, but I think you've cornered the market on critter home making.
« Reply #177 on: Tuesday,March 02, 2021, 03:40:02 PM »
For Gavin.....one last pile of critter debris.....
« Reply #178 on: Monday,March 08, 2021, 12:39:17 PM »
Some progress this past week, removed alternator, sway bar, loosened all front suspension bolts (none are stuck in the chassis now  :))), removed shift linkage from transaxle, removed roll pins from u-joint flanges, pulled valve cover just to see how things look (pic attached)..... Ordered a stock distributor (mine is crusty looking and retard mechanism has missing parts).
« Last Edit: Monday,March 08, 2021, 12:48:00 PM by TurboFource »
« Reply #179 on: Monday,March 08, 2021, 02:41:00 PM »
Your cams look like they are ok. Can you see anything of your followers? You'll know a lot more when you take the rest of it apart! Fingers crossed!
