Today:
-Since everyone seems to have trouble priming the oil system on a TC, I packed the oil pump with Vaseline, primed the system with a pump up garden sprayer, while doing this I noticed the oil pressure gauge didn’t move but I just figured it was because it took quite awhile for the sprayer to push the 20W50 …
- So I decided to test the oil pressure gauge since it hasn’t been used in 50 years, I disconnected the line at the engine and used air pressure (30 psi), at first the gauge didn’t move, then it did and the more times I did it the easier it seemed to move …. maybe people aren’t having trouble getting oil pressure but the darn gauge is sticking from being dormant for years
- Installed wide band O2 sensor which involved removing exhaust as I drilled the hole for a normal O2 sensor not realizing a wideband sensor is larger O.D. … carbide burr to the rescue …. ran the cable which involved unpinning the connector and snaking it through the hole in the body and then repinned it.
- Installed crankcase breather system.
- Removed and reclocked rotor one tooth as I didn’t like the position I ended up at.
- Made a plate to cover a squarish/random hole in the front bulkhead and used it to mount my remote MC reservoir.
- Bypassed heater core because it is probably gonna leak, I don’t want to fool with it now and it’s still summer!
