Online TurboFource
Re: Europa TCST
« Reply #945 on: Sunday,April 14, 2024, 03:43:29 PM »
Hanging out with my son working on the “Distraction” ……
Lotus work to continue soon  8)
Carillo pistons, CNC ported head with roller cam, baffled oil pan, ARP bolts and studs, welded up and ported exhaust manifold, 3” down pipe and exhaust etc.
« Last Edit: Sunday,April 14, 2024, 03:47:37 PM by TurboFource »
Re: Europa TCST
« Reply #946 on: Sunday,April 14, 2024, 04:41:08 PM »
That manifold takes a big carburetor!! If the rest of the engine can handle the carburetor, it should go like stink!
Online TurboFource
Re: Europa TCST
« Reply #947 on: Sunday,April 14, 2024, 06:14:06 PM »
That’s the lower half of the intake, it’s turbocharged…..
Online TurboFource
Re: Europa TCST
« Reply #948 on: Monday,April 15, 2024, 06:57:15 AM »
I may have a problem…… currently their is TCST which has a turbo, an SVO Mustang which is a 4 cylinder turbo, a 4 cylinder Chevy Malibu LTZ turbo and the complete drivetrain out of a Merkur XR4Ti (4 cylinder turbo) at my house …..I guess my screen name is very fitting ???
Re: Europa TCST
« Reply #949 on: Monday,April 15, 2024, 08:29:51 AM »
I was thinking that!
Online TurboFource
Re: Europa TCST
« Reply #950 on: Sunday,April 21, 2024, 06:03:42 AM »
Almost done with “the Distraction “ …. Lotus work will resume tomorrow  8)
Online TurboFource
Re: Europa TCST
« Reply #951 on: Monday,April 22, 2024, 01:59:44 PM »
The struggle resumes … unfortunately I do mean struggle  :-\
The Europa specific radiator hoses I bought didn’t work, the bottom one needed cut and spun because the bend orientation to each other was wrong and the bend was larger so I had to trim some fiberglass to get it on the coolant tube. The upper one needed cut and spun to reorient the bends and shortened almost 2 inches  :(.  Adding two pieces of aluminum tubing and 4 more hoses clamps is not “simplify”. The clutch cable abutment bracket holes did not line up with the original hole spacing and were closer together so I made a threaded plate to spread the load….why does everything have to be a challenge  :confused:
« Last Edit: Monday,April 22, 2024, 02:10:02 PM by TurboFource »
Re: Europa TCST
« Reply #952 on: Monday,April 22, 2024, 05:14:43 PM »
Quote
It’s a Europa, Turbo! That’s why!  ;D
Online TurboFource
Re: Europa TCST
« Reply #953 on: Tuesday,April 30, 2024, 03:25:25 AM »
Still plugging along …. nothing picture worthy ….
Re: Europa TCST
« Reply #954 on: Tuesday,April 30, 2024, 07:01:50 AM »
  Turbo, I feel your pain,  :I-agree:
 I made a bracket for the clutch cable also. my hoses weren't perfect either off Ebay ,but I'm sure you'll work it out. Sometimes it feels like I'm going in circles so then I start another task that will also give me a problem. Makes sense doesn't it? :headbanger:
 so just keep moving forward.
D'man
Re: Europa TCST
« Reply #955 on: Tuesday,April 30, 2024, 07:18:11 AM »
*** DELETIA****
...why does everything have to be a challenge  :confused:
Never surprised at anything I come across.  I think it comes down to the manual assembly nature of the car and the 'as it comes down the line, make it fit' nature of the production.  EVERYTHING takes a bit of 'fettling'.
Online TurboFource
Re: Europa TCST
« Reply #956 on: Saturday,May 04, 2024, 06:34:49 PM »
Went to a British car show today because the featured marque was Lotus ….ironically the
damp gloomy English weather kept the cars away …. ???
Re: Europa TCST
« Reply #957 on: Saturday,May 04, 2024, 06:44:25 PM »
Minus the white circle, that Elan is sexy AF!
Online TurboFource
Re: Europa TCST
« Reply #958 on: Saturday,May 04, 2024, 07:15:14 PM »
It was beautiful!
Online TurboFource
Re: Europa TCST
« Reply #959 on: Monday,May 06, 2024, 01:04:24 PM »
Made an adjustable pedal stop so I can easily adjust how close the pedals are to me…
I was able to salvage the passenger seat track to use on the drivers seat because it’s set was fairly dissolved from water like the pedal set was …. so much to my dismay but also logical, the seat foam absorbed that water like a sponge and lightened the seat far more than I anticipated   :-\
Is there a seat drawing available ?
What are seat options? Thought I was past the fabrication stage ….  :o :(
