Author Topic: Europa TCST  (Read 132582 times)
Re: Europa TCST
« Reply #750 on: Monday,February 06, 2023, 10:13:32 AM »
   :FUNNY:
   Totally unacceptable!
  Like the tires also .
Re: Europa TCST
« Reply #751 on: Monday,February 06, 2023, 11:12:13 AM »
Almost ready to   :welder:
Re: Europa TCST
« Reply #752 on: Monday,February 06, 2023, 12:18:24 PM »
Don’t make the bushing/shaft fit too snug.  The assembly may flex a bit when it tighten down to the floor.
Re: Europa TCST
« Reply #753 on: Tuesday,February 07, 2023, 05:23:11 PM »
   I didn’t intend to prove anyone wrong, it was my frustration thinking I put them in wrong. I can’t believe they made it harder to remove. The s2 does have the clearance either way.
  dakazman
I know D'man - my apologies. It was a figure of speech and not my intention to offend.
Looking at your pic with the tape measure, I'm trying to account for parallax error. What would you say is the distance between the bolt head and the fibreglass?
Offline kram350kram
Re: Europa TCST
« Reply #754 on: Wednesday,February 08, 2023, 08:36:33 PM »
Turbo, see you made some motor mounts. Nice job. Did you consider  solid mounts for both motor and transmission? Thinking solid mounts would make the suspension pick up points stable and suspension movements more accurate. Would  pick up some vibration but might be a good trade off? Ran my V-8 on a solid test stand yesterday and it got me thinking what is the advantage of rubber mounts; vibration control, not cracking the block?
Re: Europa TCST
« Reply #755 on: Thursday,February 09, 2023, 01:49:02 AM »
Kram,
They are 86 durometer so hopefully they will limit motion!
The tranny ones I poured are definitely stiffer than what I replaced.
Re: Europa TCST
« Reply #756 on: Thursday,February 09, 2023, 10:59:40 AM »
  About 3 1/2" Gavin, and remember it my bend in the rubber mount to angle it slightly more.
 dakazman
Re: Europa TCST
« Reply #757 on: Thursday,February 09, 2023, 02:05:51 PM »
New billet compressor wheel and new turbine shaft, because it is lighter and will spool up easier (also more efficient etc), they even balanced them as an assembly gratis 8)
(All the internal parts will be new and cost more than a new questionable quality chinesium turbo but this turbo will remain all Made in USA!)
« Last Edit: Thursday,February 09, 2023, 02:18:06 PM by TurboFource »
Re: Europa TCST
« Reply #758 on: Thursday,February 09, 2023, 02:33:02 PM »
The turbo should be good for at least 150,000 miles.....I think the life expectancy of a boosted Twink is somewhat shorter  :-\
« Last Edit: Thursday,February 09, 2023, 02:35:05 PM by TurboFource »
Re: Europa TCST
« Reply #759 on: Thursday,February 09, 2023, 02:41:41 PM »
Sticking with the turbo theme on life....my favorite wine (18%)
Re: Europa TCST
« Reply #760 on: Thursday,February 09, 2023, 03:05:28 PM »
Wouldn’t that be more of a ported wine?
Re: Europa TCST
« Reply #761 on: Thursday,February 09, 2023, 03:42:46 PM »
Kendo,
It certainly seems so! A glass of this changes your perspective ::)
Re: Europa TCST
« Reply #762 on: Saturday,February 11, 2023, 12:20:12 PM »
Almost done with pedals.....left some room to use shaft collars so I can
be sure brake pedal is lined up with master cylinder to prevent any side loading on
piston....
Re: Europa TCST
« Reply #763 on: Saturday,February 11, 2023, 02:10:02 PM »
  The pedals definitely look good.
  I see too that they the TCs' jog outward more than an S2s'.
  I can't wait to see more of your Turbo pics. I don't drink wine much except to finish my wife glass.  :FUNNY:
Re: Europa TCST
« Reply #764 on: Saturday,February 11, 2023, 02:39:07 PM »
Going by that drawing D'man as I had nothing left of mine really to go by.....may end up bending them :confused:
