Online TurboFource
Re: Europa TCST
« Reply #585 on: Tuesday,August 09, 2022, 12:25:54 PM »
I am looking forward to cooler weather so I can spend more time in the garage,
it's been quite hot this year! May need to consider A/C for garage next year!
Re: Europa TCST
« Reply #586 on: Tuesday,August 09, 2022, 12:32:51 PM »
Many years ago, I got a great deal on a  used 1200 BTU window unit. It doesn't keep the garage cool but it cuts a lot of the humidity so it's much more comfortable!
Re: Europa TCST
« Reply #587 on: Tuesday,August 09, 2022, 02:14:15 PM »
Was thinking of one of those floor mounted units with the dryer vent for the exhaust...my garage has no windows, so, I'd have to punch a hole thru the siding, but, if it keeps the space cool...and found one that also acts as a heater...ideal for those winter evening projects...;)
« Last Edit: Tuesday,August 09, 2022, 02:17:27 PM by Bryan Boyle »
Online TurboFource
Re: Europa TCST
« Reply #588 on: Thursday,August 11, 2022, 01:21:41 PM »
Trying to reduce flow bias to the outside ports since they are siamesed...made intake port vanes..they go into the siamesed port about 3/8" or so ..,.. Ready to weld....
« Last Edit: Thursday,August 11, 2022, 01:41:43 PM by TurboFource »
Online TurboFource
Re: Europa TCST
« Reply #589 on: Wednesday,August 17, 2022, 01:51:22 PM »
Flange for turbo made and intake welded together.
Re: Europa TCST
« Reply #590 on: Wednesday,August 17, 2022, 05:05:29 PM »
Nice work, Turbo!
Online TurboFource
Re: Europa TCST
« Reply #591 on: Thursday,August 18, 2022, 05:34:06 PM »
Trying to figure out how to get from header to turbo....space is a premium!
« Last Edit: Thursday,August 18, 2022, 05:44:18 PM by TurboFource »
Re: Europa TCST
« Reply #592 on: Thursday,August 18, 2022, 05:43:43 PM »
Damn those cross flow engines!
Online TurboFource
Re: Europa TCST
« Reply #593 on: Friday,August 19, 2022, 12:08:58 PM »
This will work.....I can reclock the exhaust housing to any position 8)
Online TurboFource
Re: Europa TCST
« Reply #594 on: Monday,August 22, 2022, 01:41:44 PM »
Cleared and baked intake today with high heat satin clear with ceramic in it... Looks shinier than satin, oh well.
Header collector looked restrictive (see pic from 8/18/22)...can't have that! :o Opened it up and welded new flange on.
Old bent copper penny (can't use a newer penny that isn't solid copper) and bent welding wire to back up thermocouple holes that I wanted to fill in with weld since I will be using wideband O2 sensor and gauge.
Trying to get bolts loose to reclock turbo >:(
« Last Edit: Monday,August 22, 2022, 02:08:27 PM by TurboFource »
Re: Europa TCST
« Reply #595 on: Monday,August 22, 2022, 01:48:58 PM »
Great job with that intake manifold!  :welder:
Online TurboFource
Re: Europa TCST
« Reply #596 on: Friday,August 26, 2022, 04:11:17 PM »
5 out of 5 bolts broke on exhaust/waste gate housing after soaking with penetrant for a week, using a torch, working back and forth etc.... >:( I have gotten two out so far...more fun tomorrow with them!
V-band adapter came in. Headers sanded, primed and painted with 2000 degree ceramic paint...will bake them Monday when the wife is not home ::)
Online TurboFource
Re: Europa TCST
« Reply #597 on: Saturday,August 27, 2022, 11:06:43 AM »
 8) TIG welder to the rescue!
Re: Europa TCST
« Reply #598 on: Saturday,August 27, 2022, 11:10:58 AM »
Good job!!  :beerchug:
I've seen videos of that being done but yours didn't look like there was enough meat on the old studs to do that.
Online TurboFource
Re: Europa TCST
« Reply #599 on: Saturday,August 27, 2022, 11:19:05 AM »
Thanks BDA....it was  a little challenging to weld to them :o
