Author Topic: Europa TCST  (Read 130924 times)
Offline cwtech
Re: Europa TCST
« Reply #45 on: Friday,November 20, 2020, 05:18:21 AM »
Yes.
Re: Europa TCST
« Reply #46 on: Monday,November 23, 2020, 08:11:48 AM »
Early turbo manifold.....for side draft weber.....water injection point....floating discs between upper chamber and lower to create a "priority breather valve" to allow direct path from carb to intake until boost starts to build and then intake charge was drawn through turbo....I believe there were issues due to lack of compressor side seal...CW?
Re: Europa TCST
« Reply #47 on: Monday,November 23, 2020, 08:18:28 AM »
Discs went here on the two shafts.....
Re: Europa TCST
« Reply #48 on: Monday,November 23, 2020, 09:39:26 AM »
I think there are a LOT better ways to build turbo systems now.
Re: Europa TCST
« Reply #49 on: Monday,November 23, 2020, 01:45:28 PM »
There are JB, just thought the pics were worth posting from a historical perspective...will take detailed pics of current system when I pull the engine. It will be upgraded when I rebuild the engine.
Made some minor progress today. Decided to I am going to pull the seats as they wont move and I can't reach the pedals, and pull the pedals because they need work, that way I can work on this stuff while the body is off and I am working on chassis etc. Will probably pull the doors too as the hinges need attention.
Well....since the seats won't move this is proving to be a fun task! Front two bolts came out but I am having to drill bolts out of the bobbins from underneath on the rear bolts. Tried to unbolt the seat from the track but they just spin. I ended up having to drill one size over tap drill size (I was off a bit) but I can always drill for 3/8-16 threaded holes. I had to stop as my cordless drill needs charged.
It is obvious the seats need rust repair too.......
Good thing I don't get upset easily!
« Last Edit: Monday,November 23, 2020, 06:31:02 PM by TurboFource »
Re: Europa TCST
« Reply #50 on: Wednesday,November 25, 2020, 04:22:31 AM »
Are there drawings of the seats available?
Offline Dan C 2624R
Re: Europa TCST
« Reply #51 on: Wednesday,November 25, 2020, 12:34:04 PM »
RD has replacement seats.  I bought two for my TC.  They are in pieces and assembled using pop rivits.  My seats were so bad I didn't want to waste time trying to refurbishing them.  I believe Ray still has them available
Re: Europa TCST
« Reply #52 on: Wednesday,November 25, 2020, 01:57:02 PM »
Thanks.....don't have mine out yet....will see how bad they are.
Re: Europa TCST
« Reply #53 on: Sunday,November 29, 2020, 01:13:48 PM »
 :o
Having trouble getting the damper out of the piston.....
Re: Europa TCST
« Reply #54 on: Sunday,November 29, 2020, 01:27:14 PM »
Yikes! It might be time for new carburetors!
Re: Europa TCST
« Reply #55 on: Sunday,November 29, 2020, 01:44:09 PM »
Heat the outside with an hot air gun and spray the piston with freeze spray — Dust Off upside down works very well.
Re: Europa TCST
« Reply #56 on: Sunday,November 29, 2020, 06:30:09 PM »
The piston came out of carb body and actually looks like it will clean up well, can't get the damper out of the piston.....have it soaking in penetrating fluid....I have the other carb since the turbo set up only uses one carb. Will try to save this one so I have a spare.
Re: Europa TCST
« Reply #57 on: Sunday,November 29, 2020, 07:38:35 PM »
I would suggest going to adjustable needles using "pistons" from a TR6 or TR7.  You just need to swap the Lotus unadjustable needle (preferably Euro-spec) into an adjustable holder.
Change the needle jets!  They wear and make the carbs difficult to set.
Re: Europa TCST
« Reply #58 on: Monday,November 30, 2020, 11:28:08 AM »
Persistance, and patience and the damper is now out of the slide, cleaning up nicely considering....diaphragm isn't even torn....
Re: Europa TCST
« Reply #59 on: Monday,November 30, 2020, 11:52:39 AM »
Boy those cleaned up great!
