Author Topic: Europa TCST  (Read 131312 times)
Re: Europa TCST
« Reply #375 on: Monday,November 01, 2021, 03:59:11 PM »
Someone’s been busy!  :)
Good work! Looking good!
Offline kram350kram
Re: Europa TCST
« Reply #376 on: Monday,November 01, 2021, 07:01:15 PM »
Hey Turboforce, just a heads up on the Koni's, make sure you take apart the lower shaft adjustment valving; bolt in the end out, adjustment tab unscrewed, spring, then screw the piston off the shaft, small washers and wavy washers too. The lower valving in the tube end needs to come apart too. That one really get clogged with many .024 diameter holes.  The solidified gunk gets in the very small orfices and has to be physically removed. I have done probably 75 Koni's and each one needed the valving cleaned or the adjustment feature will not work.
Online TurboFource
Re: Europa TCST
« Reply #377 on: Tuesday,November 02, 2021, 04:47:37 AM »
Thanks for the input Kram. I think I got all the crud out of the passages, I will check again before I reassemble them!
Online TurboFource
Re: Europa TCST
« Reply #378 on: Wednesday,November 03, 2021, 04:27:55 PM »
My favorite brown truck showed up today 8)
Drilled/slotted discs, stainless brake hoses, caliper and suspension rebuild stuff, material and oil lite bushings to refabricate pedal assembly :)
Re: Europa TCST
« Reply #379 on: Wednesday,November 03, 2021, 04:55:12 PM »
Christmas in November!!!  :beerchug:
Online TurboFource
Re: Europa TCST
« Reply #380 on: Monday,November 08, 2021, 12:40:34 PM »
Got these drivers side pieces cleaned up and painted today :)
I think I am almost ready to start assembling the front suspension...;)
Re: Europa TCST
« Reply #381 on: Monday,November 08, 2021, 12:47:42 PM »
It's a great day when you start putting parts on the car rather than taking them off and cleaning them!!! Congratulations!!  :beerchug:
Offline Jmarkusic
Re: Europa TCST
« Reply #382 on: Thursday,November 18, 2021, 02:53:26 PM »
 :beerchug:
Offline Chuck Nukem
Re: Europa TCST
« Reply #383 on: Thursday,November 18, 2021, 03:04:19 PM »
Excellent!
Re: Europa TCST
« Reply #384 on: Thursday,November 18, 2021, 04:26:19 PM »
    :trophy:  Every little bit helps.
One day I’ll count the number of parts we recondition during a rebuild. Looking 👍.
Online TurboFource
Re: Europa TCST
« Reply #385 on: Friday,November 19, 2021, 02:13:26 PM »
I modified the upper front Koni spring perches with billet aluminum adjustable collars.
(They fit much better on the upper perch). I am using needle bearings between the springs and perches as suggested in " Autocross To Win". Coil springs can "twist" when they compress creating unwanted loads and the bearings will help prevent this. They also make adjustment easier as you eliminate the increasing friction between the perch and spring as you increase the preload. They will also help prevent the "twist" of the spring from trying to adjust your preload for you  :o
« Last Edit: Friday,November 19, 2021, 02:24:09 PM by TurboFource »
Re: Europa TCST
« Reply #386 on: Friday,November 19, 2021, 02:35:58 PM »
Nice!  :BEER3:
Offline Dan C 2624R
Re: Europa TCST
« Reply #387 on: Friday,November 19, 2021, 07:58:03 PM »
Turbo,  I saw this by chance on Facebook tonight.  A turbo with what looks like a 175 carb
https://www.facebook.com/photo/?fbid=4905639019470380&set=pcb.10159464118015871
Dan in NJ
2624R
Re: Europa TCST
« Reply #388 on: Friday,November 19, 2021, 09:42:45 PM »
Looks like an 1 3/4" HS type SU carb.  Might be 2".
Online TurboFource
Re: Europa TCST
« Reply #389 on: Saturday,November 20, 2021, 04:39:25 AM »
I think it's gone already....
