Author Topic: Europa TCST  (Read 131312 times)
Re: Europa TCST
« Reply #210 on: Thursday,March 25, 2021, 04:15:39 PM »
Just make them.  I'd use SS.
Online TurboFource
Re: Europa TCST
« Reply #211 on: Sunday,March 28, 2021, 08:17:41 AM »
Met my goal having chassis flipped by the end of March :beerchug:
Now to repair T-section.... ???       The big hole I cut to hacksaw through brake rod.....
Re: Europa TCST
« Reply #212 on: Sunday,March 28, 2021, 08:21:37 AM »
Congratulations on your milestone, Turbo!  :beerchug:
Online TurboFource
Re: Europa TCST
« Reply #213 on: Sunday,March 28, 2021, 08:45:05 AM »
Will have to fold pattern in half to recreate left hand drive pedal mounting as it was to far gone for an accurate pattern.....
Offline literarymadness
Re: Europa TCST
« Reply #214 on: Sunday,March 28, 2021, 04:26:03 PM »
What is your next milestone?
Offline Dilkris
Re: Europa TCST
« Reply #215 on: Sunday,March 28, 2021, 04:38:44 PM »
I admire you taking on that chassis repair - kudos to you. I am not that brave and do not have that skill set. Mine was the same, but being over the pond it went to Spyder Engineering and came back with a more user friendly T section for access.
Re: Europa TCST
« Reply #216 on: Sunday,March 28, 2021, 05:13:29 PM »
Dilkris: S.E. did a great job!
Re: Europa TCST
« Reply #217 on: Sunday,March 28, 2021, 05:48:02 PM »
That’s very similar to (or maybe the same as) my frame. I didn’t know they made frames other than their tubular space frame. The extra access to the steering u-joint is really great!
Online TurboFource
Re: Europa TCST
« Reply #218 on: Sunday,March 28, 2021, 06:21:04 PM »
Yours looked worse than mine Dilkris! My suspension attachment points are all still intact.
Literary....hope to have chassis repaired and painted by the end of April... :welder:
Re: Europa TCST
« Reply #219 on: Sunday,March 28, 2021, 07:15:00 PM »
Both Banks and Spyder will replace rotten “T” sections on standard frames.  Be nice to live in Jolly Old for that reason.
Re: Europa TCST
« Reply #220 on: Sunday,March 28, 2021, 07:17:17 PM »
When converting an S2 frame to S1 specs, I didn’t drill it for the pedal assembly until after I’d modded it.  You could even do it after the body is mounted if you wanted.
Online TurboFource
Re: Europa TCST
« Reply #221 on: Wednesday,March 31, 2021, 06:15:47 PM »
Started removing lower piece of T-section.....too rusty to tell where spot welds are and drill them... ??? Looks like I will be grafting in new metal for the first couple of inches of the vertical pieces too
Re: Europa TCST
« Reply #222 on: Thursday,April 01, 2021, 05:59:44 PM »
I certainly haven’t looked at the welds on my frame nearly as closely as you, but I don’t recall seeing any spot welds. I think they were mostly intermittent welds.
Online TurboFource
Re: Europa TCST
« Reply #223 on: Friday,April 02, 2021, 12:33:59 PM »
Where the sheet metal T-sections overlap and where the internal pieces are welded in are done with "spot" welds. There are a couple of stitch welds at the pedal attachment plates at the rear of the T-section to add support and I would imagine to keep from flexing at the spot welds, and of course stitch welds where the T is attached to the rest of the chassis.
Re: Europa TCST
« Reply #224 on: Friday,April 02, 2021, 04:59:29 PM »
   Turbo, I have an S2 so I used these dimensions ( zoom in to see dimensions)
http://lotus-europa.com/manuals/misc/Lotus%20europa%20chassis%20drawing.pdf
  Maybe you can compare and document your findings. I have to add my pedal assembly plate to the frame now after body on. I have the original plate and can check where welds were made.
