Author Topic: Europa TCST  (Read 131312 times)
Re: Europa TCST
« Reply #150 on: Sunday,February 14, 2021, 12:54:28 PM »
Nope. The S2 and probably the S1 had bolts behind the seats but not the TC or TCS.
It sounds like you’re ready for liftoff!!  :pirate:
Re: Europa TCST
« Reply #151 on: Sunday,February 14, 2021, 12:59:19 PM »
BTW - here are plans for the outer/lower seatbelt anchor: https://drive.google.com/drive/folders/1pWkOZ6a7g3D0iWUf8aY6Rpc9WfbVqxQT
Online TurboFource
Re: Europa TCST
« Reply #152 on: Sunday,February 14, 2021, 01:16:30 PM »
Thanks BDA!
I have to reorganize the mess I have created getting to this point before lift off will commence :trophy:
Online TurboFource
Re: Europa TCST
« Reply #153 on: Thursday,February 18, 2021, 01:43:47 PM »
BDA has come to the rescue with my dash drawing/pattern issue....thanks BDA :pirate:
Re: Europa TCST
« Reply #154 on: Thursday,February 18, 2021, 02:29:39 PM »
You're very welcome! I'm glad I could be of help!
Online TurboFource
Re: Europa TCST
« Reply #155 on: Sunday,February 21, 2021, 12:36:00 PM »
Some minor progress today, removed deck lid and body seems to lift up from chassis when I lift at various points on body.
Reorganizing the mess I created today, took the oppurtunity to weigh some parts:
Original turbo system (minus carb)             56.3lbs
Brake boosters with brackets.                     13.2lbs
Exhaust with Corvair turbo muffler.             18.6lbs
Breather system                                         5.7lbs
Door panels w/speakers.                             8.7lbs
Center console                                             .7lbs
Spare wheel and tire.                                29.1lbs
Radiator (original).                                    22.6lbs
Radiator fan.                                              4.2lbs
Closing plate (very rusty).                           4.2lbs
Seat w/tracks.                                          24.8lbs
Battery.                                                   32.9lbs
Pics      Soaking parts in vinegar to remove rust (some before and after).
This is just regular white vinegar, next time I will buy "cleaning" vinegar which is twice as strong.
It takes several days but it is basically non-toxic .....neutralized with baking soda water mix after soaking then dried parts.
« Last Edit: Sunday,February 21, 2021, 12:42:06 PM by TurboFource »
Re: Europa TCST
« Reply #156 on: Sunday,February 21, 2021, 12:57:54 PM »
Vinegar is a nice idea. It's a lot cheaper than Naval Jelly!
Online TurboFource
Re: Europa TCST
« Reply #157 on: Sunday,February 21, 2021, 01:10:19 PM »
A bit more reorganizing to do and I will be ready for lift off😎
I plan to use a system with two block and tackles in the front and one centered over the engine compartment, after lifting high enough I was thinking of sliding a wooden "T" made out of  2 x 4s to simulate the chassis and hoist it up to my garage ceiling (11') to keep the body out of the way for chassis and running gear restoration. Should this adequately support the body?
Re: Europa TCST
« Reply #158 on: Sunday,February 21, 2021, 01:26:51 PM »
I think that should do it. I would align them vertically so you get extra rigidity.
It might be simpler to have two 2x4s, one under the front jack points or across the 'T' and one under the rear jack points and hold it up that way.
It's not that heavy. I think three men could pick it up without problem. I held mine up on two pretty rickety saw horses.
Offline gideon
Re: Europa TCST
« Reply #159 on: Sunday,February 21, 2021, 02:08:00 PM »
I used 4 ratchet straps.  One attached to each of the 4 corner mounting points on the body, going up to padeyes screwed into the ceiling beams.  I had one pair of helping hands and that was enough.  The ratchets let us lift the body bit by bit and without having to hold the body ourselves.   However you do it, having some way to lift a bit and then lock the lifting tackle, while you investigate, is a good idea.  Being able to take your time and check to see what's happening takes a lot of the stress out of it.
Online TurboFource
Re: Europa TCST
« Reply #160 on: Monday,February 22, 2021, 10:20:14 AM »
More organizing today so I decided to start work on carb too.....
Pics:
1) 40+ year old gas.....now varnish
2) Initial cleaning in ultrasonic cleaner
3) Now soaking in Pine Sol water mix will put back in ultrasonic cleaner after Pine Sol bath
4) Starting pic
« Last Edit: Monday,February 22, 2021, 11:57:23 AM by TurboFource »
Re: Europa TCST
« Reply #161 on: Monday,February 22, 2021, 10:53:46 AM »
I guess you got a barn find. Too bad it spent all its time under the barn!
Re: Europa TCST
« Reply #162 on: Wednesday,February 24, 2021, 08:54:11 AM »
haha, that made me laugh.
That's some pretty special stuff in the carb bowl. Has it come clean?
Online TurboFource
Re: Europa TCST
« Reply #163 on: Wednesday,February 24, 2021, 12:26:33 PM »
Working on it.....
Re: Europa TCST
« Reply #164 on: Wednesday,February 24, 2021, 12:32:12 PM »
That looks A LOT better!!!  :beerchug:
