I decided to take the glass off the gauges to clean them and to paint the rusty trim pieces in the tach and speedo.
I first tested the temp and fuel level gauges by just using my 6 volt trickle charger and they both moved so they should be good. I already know the tach and oil pressure gauge work from first run. I will check the speedo with my drill.
The small gauges were much more challenging to get apart than the tach and speedo! I removed the gauge to dash gasket with an exacto blade. I then carefully worried the bezel loose with a flat blade screwdriver, I also applied WD40 to bezel gaps on the small gauges with a model paint brush. I bought a strap wrench but it was useless and used a work glove with a grippy material on it to get the bezels loose. On the small gauges the original bezel to glass sealant turned into some kind of mystery gritty material
Now to clean, touch up, paint and reassemble…..
