Author Topic: Europa TCST  (Read 132585 times)
Re: Europa TCST
« Reply #1050 on: Monday,October 21, 2024, 01:49:17 PM »
It’s alive  :trophy: :beerchug: :pirate: !
Started the day off fixing carb flooding … bench checked it with pump running for 5 minutes with no issue.
Reinstalled my fuel pumps as I wanted to make sure there were no leaks there either (great fun to reinstall  :-\)
And it started up and ran for about 30 seconds, restarted and then wouldn’t restart …. Head scratching ensued …. Checked several things over and ended it up the plugs fouled from all the oil in the cylinders from assembly … cleaned them and ran it for several minutes  8)
I have a video my phone but no idea how to post it?
( Note to future me - .062” bypass is 2 & 2.5psi, .077” bypass is 1.5 & 2psi)
« Last Edit: Monday,October 21, 2024, 06:40:28 PM by TurboFource »
Re: Europa TCST
« Reply #1051 on: Monday,October 21, 2024, 02:03:00 PM »
Woohoo!!!  :pirate:  :beerchug:
Congratulations!!!
(post the video to somewhere like youtube or rumble and then provide a link.)
Re: Europa TCST
« Reply #1052 on: Wednesday,October 23, 2024, 07:06:45 AM »
Congratulations indeed!  A LOT of work and soon to be well rewarded.
Fuel pump:
If I understand correctly, you are using a metered bleed to lower your fuel pressure.  If you are getting the "correct" pressure in a no load situation, your pump is definitely not going to keep up when that turbo kicks in.
Offline cwtech
Re: Europa TCST
« Reply #1053 on: Wednesday,October 23, 2024, 09:01:25 AM »
I happen to agree with JB regarding fuel pressure regulation.
Pressure regulation by a fixed orifice only works if there is a steady-state condition.
When variable volume is needed to compensate for variable rpm and load, a fixed orifice is not what you want.  ....That is why  regulators for gases and liquids are spring-loaded.
A regulator can be installed with, or without, a bypass.
I had inconsistent results with the cheap dial-type regulators.   ....I bought that Holley pressure regulator and that maintained the desired fuel pressure under variable flow conditions.   ....Did you consider using that, or check to see if it is compatible with ethanol gas?
Re: Europa TCST
« Reply #1054 on: Wednesday,October 23, 2024, 02:06:14 PM »
A second pump comes on at 4lbs of boost ……I have an AFR gauge that will be closely watched too.
The main goal was to get it running, I bought a regulator that was a piece of junk, will pursue a better one.
Thanks for the comments CW & JB! Not sure I would trust the 50 year old one!
« Last Edit: Thursday,October 24, 2024, 04:30:10 AM by TurboFource »
Re: Europa TCST
« Reply #1055 on: Thursday,October 24, 2024, 03:24:37 AM »
4 years ago today I bought TCST …. some how I thought I would be a little farther along than I am  ???
« Last Edit: Thursday,October 24, 2024, 04:32:04 AM by TurboFource »
Re: Europa TCST
« Reply #1056 on: Monday,October 28, 2024, 02:18:52 PM »
Working on a permanent solution to my fuel bypass setup. Decided to start prepping my “decent” dash as it needs a little repair work and will probably re-clear it. Decided to pull the crummy original as I bought a new DB10 lighting relay, voltage stabilizer for the gauges and washer pump and figured I should check out the heater core as first drive will probably be in cold weather  8) Removing the demist bezels without removing the windshield was challenging! I have a new windshield but do not want to install it until bodywork is completed.
« Last Edit: Monday,October 28, 2024, 02:21:53 PM by TurboFource »
Re: Europa TCST
« Reply #1057 on: Monday,October 28, 2024, 03:35:43 PM »
You're going to have to show me pictures of the screwdrivers (or give detailed instructions) you used to take the demist bezels off before I'll believe you did it with the windshield in place!
Re: Europa TCST
« Reply #1058 on: Monday,October 28, 2024, 03:50:39 PM »
  It looks really nice turbo . Definitely re-clear it, even the backside. I can't imagine installing a radio,but love siding toward original. Hat's off to you.
   It may be beneficial to add a little extensions to the the DB-10 wiring. Also think about some other solution for the steering wheel mount. I HATE TIGHTENING THOSE NUTS.  :FUNNY:  BUT TRUE.
Re: Europa TCST
« Reply #1059 on: Monday,October 28, 2024, 06:18:04 PM »
Here ya go BDA …. shortened a bit with my Dremel … it was no fun to do but I am very patient  ???
D’ man I have removed and installed those nuts once already and dread doing it again … maybe I can come up with something ….
« Last Edit: Monday,October 28, 2024, 06:20:50 PM by TurboFource »
Re: Europa TCST
« Reply #1060 on: Monday,October 28, 2024, 10:17:58 PM »
For tight jobs like these, I got a 'proper' chinesium implement for about $A4.00.
Yet to be tried on the demister bezels but the S2 ones aren't as high as the TCS ones, I think.
Re: Europa TCST
« Reply #1061 on: Tuesday,October 29, 2024, 03:28:35 AM »
I thought I had one of those Gavin, somewhere ……..
D’Man what kind of extensions? Are the wires to short?
« Last Edit: Tuesday,October 29, 2024, 04:35:30 AM by TurboFource »
Re: Europa TCST
« Reply #1062 on: Wednesday,October 30, 2024, 10:58:16 AM »
Jerry Johnson (of founder of lotus-europa.com fame) did it by cutting down a philips bit and welding it on to the end of a paint scraper.  It's doable, but fiddly.
Re: Europa TCST
« Reply #1063 on: Wednesday,October 30, 2024, 12:01:55 PM »
I don't remember exactly but I have a strong feeling that when I built my car, I used screws that were much to long to take out with the windshield in place. I guess I figured it was a lost cause... sigh... :o
Re: Europa TCST
« Reply #1064 on: Wednesday,October 30, 2024, 12:40:13 PM »
The screws are longer than they need to be!
