Author Topic: Europa door hinges  (Read 516 times)
Offline Bud
  • 416-949-2778
Europa door hinges
« on: Saturday,October 24, 2020, 03:30:17 PM »
Is there a good way to substitute worn door hinges for the new after market type
Re: Europa door hinges
« Reply #1 on: Saturday,October 24, 2020, 03:32:24 PM »
I used Banks hinges. Once adjusted, you can remove a door without upsetting the set position.
« Reply #2 on: Saturday,October 24, 2020, 03:40:09 PM »
  I got a set of ss hinges , very easy to install.
« Reply #3 on: Wednesday,October 28, 2020, 11:20:17 AM »
Bud, it depends on what is worn in your hinge system. If the adjustable bits in the door are worn, the hinge pin or bushings, then either the stainless or Banks brass hinges would be a fairly easy fix. If the bobbins in the body are worn or loose, that is a much bigger repair. I went with the Banks hinges. They are very easy to use once set up.
