Author Topic: S2 VS TC carpets whats the differance?  (Read 649 times)
Offline aspares
« on: Friday,October 09, 2020, 01:52:04 PM »
I have been offered a new carpet set for a TC Europa (free) but I have a S2. What would the difference be and could it be made to work? He also has some of the carpet material in a roll that I could use if needed.
Thanks as always for any info.
Re: S2 VS TC carpets whats the differance?
« Reply #1 on: Friday,October 09, 2020, 01:59:46 PM »
If you look at AutoMats website, their carpet kit is for all Europa models, no differentiation between the S2 or TC.
« Reply #2 on: Friday,October 09, 2020, 03:19:38 PM »
I thought the TC cockpit got bigger. Or was it S1 -> S2 that got bigger?
« Reply #3 on: Friday,October 09, 2020, 06:34:31 PM »
Free, I would make it work. ^-^ I know the seats are different as far as rake so the back is a little different. I'm sure some on here will know definitively.
« Reply #4 on: Friday,October 09, 2020, 11:03:47 PM »
 :)  Ditto !
Especially as you have access to more of the same material, it's a no-brainer !
I don't know the detail changes but the cockpit was enlarged for the TC, it's mentioned in several period road tests. Apart from the seat angle (which might not make a big  difference to the carpets ?) they enlarged the footwells to give a bit more room. As those areas are well out of sight you should be able to sort something out with extra material.
A quick look at the parts manuals for the S2/TC shows only minor differences - footwells and the treatment at the rear of the central tunnel. I'd reckon if the carpets were free it's worth a shot !
