Author Topic: Front disc brakes will not release on 72 Europa Twin Cam  (Read 2384 times)
Offline marks
Re: Front disc brakes will not release on 72 Europa Twin Cam
« Reply #15 on: Thursday,September 17, 2020, 07:20:06 AM »
I removed the pads; and they all seem to be tight; both sides.
« Reply #16 on: Thursday,September 17, 2020, 09:35:31 AM »
They should move along the two pins freely, but not too freely. .
« Reply #17 on: Thursday,September 17, 2020, 09:42:00 AM »
Pads removed, are the wheels now free?
You can sand excess pad thickness off with sandpaper and a flat surface.
« Reply #18 on: Thursday,September 17, 2020, 10:19:25 AM »
My problem was the metal backing plates were rough and didn't slide in the calipers properly, not the thickness of the brake pad material.
Offline marks
« Reply #19 on: Sunday,September 27, 2020, 09:38:50 AM »
I solved one of the problems on my brake issue as the pads were too thick for the rotors.  Second problem:  I have rebuilt the brake master cylinder and there is pressure coming out of the rear port (closest to the firewall) but no pressure coming out of the front port.  Suggestions?
« Reply #20 on: Sunday,September 27, 2020, 10:31:06 AM »
Air! Are you trying bench bleeding?
Offline marks
« Reply #21 on: Sunday,September 27, 2020, 12:26:12 PM »
Yes, I am trying bench bleeding.
« Reply #22 on: Sunday,September 27, 2020, 03:40:13 PM »
35 year as a mechanic and I don't rebuild brake masters anymore.  I only fit new.  When I'm screaming down a mountain pass, I want them to work.  If you are restoring a trailer queen then originality comes into play.  Driver?  Just fit new.
Offline MRN I J
    • Four Ashes Garage
« Reply #23 on: Monday,September 28, 2020, 04:52:03 AM »
46 years as a mechanic - ditto
Regards Chris
other cars inc wifes cars
Offline marks
« Reply #24 on: Monday,September 28, 2020, 07:30:27 AM »
I appreciate the feedback buying a new brake master cylinder.  It seems like originals are not out there.  Is there one that I can use with the same port line set up, that will work as an original?  Thanks for the help!
« Reply #25 on: Monday,September 28, 2020, 08:11:03 AM »
What is the bore size of your original master cylinder?
Do you have twin brake boosters?
« Reply #26 on: Monday,September 28, 2020, 09:08:00 AM »
He says it's a 72 TC, so the unobtainable MC. There are on this forum several alternatives. I have  a Triumph Spitfire MC with remote reservoirs. I think there's a Grumblebuns post listing alternatives people have tried.
I had fitted the Datsun MC, lovely light bit of kit, but eventually it failed and can no longer be found. Shame!
« Reply #27 on: Monday,September 28, 2020, 09:52:57 AM »
Still want to know exactly what "Marks" has before making a recommendation.
Offline marks
« Reply #28 on: Monday,September 28, 2020, 09:53:50 AM »
I do have the 2 brake servos.
« Reply #29 on: Monday,September 28, 2020, 09:58:39 AM »
Do you know the bore of the master cylinder?
Are the boosters still hooked up?
Myself, heretic that I am, I would remove the boosters and "miles" extra piping.
