Author Topic: tire size only 185/60r13 available would it fit  (Read 1117 times)
Offline califkid_66
« on: Monday,August 24, 2020, 10:47:03 AM »
im trying to find tires in my area online they are backorder
i found a tire shop in my area the only tires they have
is 185/60r13 falken ze914 he as 4 left nothing else in 13
i have bwa rims 13 jj6
Offline rjbaren
Re: tire size only 185/60r13 available would it fit
« Reply #1 on: Monday,August 24, 2020, 12:31:09 PM »
I bought Barum Brillantus 2 from Discount Tire Online.  (2) 185x70x13 and (3) 175x70x13 and free shipping.  I don't know if they will ship to Canada.  888-774-6560.  Good luck.
Offline califkid_66
« Reply #2 on: Monday,August 24, 2020, 01:41:02 PM »
i tried online either they don’t ship or the shipping price is way up there
152 us for shipping
i found canadian tire distributor but the size i need ar backorder till mid september
that’s why i was asking if 185/ 60r13 would fit
« Reply #3 on: Monday,August 24, 2020, 01:56:49 PM »
It’s important that tired are true and round.  Even a little bit out and balancing will become a nightmare.  I have had good luck with Michelin Defenders and Toyo Extensa.  The Toyos come in both 185/70-13 and 175/70-13.
« Reply #4 on: Monday,August 24, 2020, 02:08:55 PM »
Try pmctire.com - they do free shipping on 4 tires or more within Canada.
Offline califkid_66
« Reply #5 on: Monday,August 24, 2020, 02:26:40 PM »
yes JB i read what you wrote about tires im taking notes
Offline califkid_66
« Reply #6 on: Monday,August 24, 2020, 02:40:46 PM »
gideon i just took a look they have what i wanted at first
but before ordering im gonna call them to make sure they have them in stock
i called pneu à rabais they had a lot listed but when i called they said backorder till mid september
thanks
Offline califkid_66
« Reply #7 on: Monday,August 24, 2020, 02:43:32 PM »
JB i need your advice again!
should i put 175/70r13 all around or
185/70r13 back and 175/70r13 front
my car is a s2 federal 1970
thanks again
« Reply #8 on: Monday,August 24, 2020, 06:59:54 PM »
Does Tire Rack ship to Canada? You can ship them to an installer of your choice.
« Reply #9 on: Monday,August 24, 2020, 09:09:14 PM »
This is an S2, right?
If so, same size of tire on all four corners.
Due to it’s heavier rear bias, a TC/S benefits from having a larger rear tire.  Typically it’s 175/70 up front and 185/70 at the rear.  Though TCs on steel wheels got 175s all round (I think).
« Reply #10 on: Monday,August 24, 2020, 09:09:56 PM »
Absolutely.
Back in the late 70's I purchased a set of Minilites from another Europa owner; partly because they were the genuine article and partly because they came with new Avon 165/60 tyres which were well regarded.
At the time, 60 aspect ratio was super low, though the diameter was smaller than stock.
The performance and grip was fantastic.
As time went by, the car developed a vibration in the rear.
I chased that vibration around for ages - balanced & swapped wheels, checked wheel centering, half-shaft balance, brake drum balance, engine & gearbox mounts . . everything.
It turns out that an 'out of roundness' had been developing.
At the first wheel swap, the problem went away but in the end, they all developed the same out of round issue - some later than others.
Offline califkid_66
« Reply #11 on: Tuesday,August 25, 2020, 08:18:29 AM »
just called pcm tires they said 175/70r13 it’s not a popular size could take three weeks  before they can get them so now my only option would be 185/60r13  falken ze914  not
sure if i should just wait it out or go with 185/60r13
need advice
« Reply #12 on: Tuesday,August 25, 2020, 10:02:58 AM »
185/60s should fit.  You have to check though.  Every Europa is slightly different.  What works on one may not on another.  The issue is tire interference with the front fender lip when you hit a bump, or uneven section, while the steering is turned.  Typically when turning into a driveway, etc.  A little bit of rubbing is not unusual but too much has been known to rip off sections of the fender!
Offline califkid_66
« Reply #13 on: Tuesday,August 25, 2020, 12:13:24 PM »
thanks again JB i think im gonna get the 185/60r13
i have 185/70r13 so according to tire comparisons the new tires are 1.5 inch lower
but then again im supposed to have 175/70r13 so .75 lower than original
Offline BobW
« Reply #14 on: Tuesday,August 25, 2020, 01:47:58 PM »
I think it will depend on your wheels' offset. 185x70 fit on the rear of my S2 but not on the front.
