Author Topic: solex to weber linkage  (Read 982 times)
Re: solex to weber linkage
« Reply #15 on: Thursday,August 20, 2020, 04:43:02 PM »
Should.  It's listed as a replacement in the knowledgebase.  Do try to get lined housing.  It makes a huge difference -- bearing in mind you have to keep it away from exhaust heat though as the liner can melt and glue everything together.
Offline califkid_66
« Reply #16 on: Thursday,August 20, 2020, 04:56:57 PM »
sorry to bother you again JB but i went on the site and could not find vw type 2 i looked at the pictures and the only ones that look like the one in your picture is from a 73 bus or a beetle the other ones have a round hook instead of the kink do you know witch one i should order
thank again for your help
« Last Edit: Thursday,August 20, 2020, 05:01:26 PM by califkid_66 »
« Reply #17 on: Thursday,August 20, 2020, 05:42:00 PM »
Offline califkid_66
« Reply #18 on: Thursday,August 20, 2020, 06:57:30 PM »
thanks i just ordered it !
should get it in 3 to 5 days
that should give me enough time to fabricate a decent bracket for my weber
thanks again for your help
Offline califkid_66
« Reply #19 on: Sunday,August 23, 2020, 06:53:35 PM »
while i am waiting for part i went to another bike store and got a tandem bike brake cable
i cut the front and joined it to the europa bracket with a bolt that was holding a brake cable on a bike
for the back since my carb is pull not push i flipped the pivot upside down and turned it 190 degrees
i put the spring on the side where the wire was and cut the part where you put the return spring and drilled a hole to put the cable locking bolt hard to explain but the pictures speek for themselves
when i will recieve my wire i can just replace this one no problem
« Reply #20 on: Monday,August 24, 2020, 01:39:59 PM »
Your work at the carb looks good, very good.  The other end?  A wee bit low-tech, but, it works!
Offline califkid_66
« Reply #21 on: Monday,August 24, 2020, 02:55:43 PM »
thanks for the compliment
ya i was trying to keep in the spirit of lotus
keeping it simple and light  im waiting on the vw cable but for now this works great
Offline Gmg31
« Reply #22 on: Saturday,August 29, 2020, 06:48:52 AM »
My local Weber specialist made this bracket for mine.
« Reply #23 on: Saturday,August 29, 2020, 07:09:09 AM »
Lots of brackets and adapters available for the DCOE/IDA carbs.  Not much for the DGVs.
