Author Topic: Brake disc to front bearing hub bolts T/C  (Read 715 times)
Offline kram350kram
« on: Wednesday,August 05, 2020, 08:14:44 PM »
In changing the brake disc rotors I noticed the 4 retaining bolts had two raised lines on their heads crossing at 90 degrees. Have never seen this making and can't find anywhere except standard AN aircraft bolts have a somewhat similar marking. Anyone know what these bolts are, (grade 6 maybe?). Worth changing to grade 8 while here? Thanks in advance.
Re: Brake disc to front bearing hub bolts T/C
« Reply #1 on: Wednesday,August 05, 2020, 08:25:37 PM »
It sounds like AN bolts. Why don't you post a picture?
« Reply #2 on: Thursday,August 06, 2020, 06:00:16 AM »
Stock disc bolts are already a higher grade.  The width and length of the shoulder is critical.  The bolts have not been a problem in use.  I have happily reused them many, many times.
Offline kram350kram
« Reply #3 on: Thursday,August 06, 2020, 07:18:23 AM »
T/C HUB BOLT
« Reply #4 on: Thursday,August 06, 2020, 08:06:40 AM »
That's not an AN bolt. I think JB is right that it's a stock bolt for that purpose and you can reuse it without worry.
Offline Chuck Nukem
« Reply #5 on: Thursday,August 06, 2020, 08:44:47 AM »
Mine were pretty corroded so I switched to AN. If they had been better I would have reused as well.
