Author Topic: F/S Dry sump TC motor  (Read 536 times)
« on: Monday,July 27, 2020, 12:17:19 PM »
This is the little history I have on this motor. The Europa TC this motor was originally installed in was used in local autocross events. The engine was removed out when the owner decided to convert the Europa to electric drive. The mileage on the engine is unknown but knowing the past usage as an autocross car, assume the engine was used hard and will require a tear down and inspection prior to installation.  The motor turns over easily although the valve clearances are very tight.
The dry sump system is of unknown manufacturer. The system includes a two stage side mount pump , oil tank and hoses.
The stock oil pan and pump is included if desired to go back to stock.
Also Included is the distributor, tubular headers, and the stock Strombergs
Asking $2900
Local pickup only, motor is located in the San Diego area.
