September 3, 2024 Forum membership reaches 1,600 !!This Community became 12 years old in April 2024.
So where do I get the British fuses. I mostly use rdenterprises.
All my lights come on with oil pressure.
If you’re replacing the bulb and housing, I asked Stern, wouldn’t you be able to get a good LED retrofit with today’s tech? His response:“The concept is correct—this is the right way to do it, an LED headlamp engineered, designed, constructed, tested, and certified/approved as such. There are excellent ones on the market, and of course also a great deal of junk. The king daddy of them all [at the time of publication] is the JW Speaker 8700 Evolution-J3, which brings almost Star Trek-level technology to the old seven-inch round headlamp format.”Stern also shouted out the “JWS 8700 Evo 2” as a good option one step down, and “another step or two down from there, [is] the Peterson Manufacturing 701C (in Peterson or Sylvania Zevo packaging — same lamp) and the Truck-Lite units are reasonably good with or without heated lens.”
