Author Topic: Twin Cam Special headlights  (Read 3719 times)
Offline gideon
Re: Twin Cam Special headlights
« Reply #45 on: Saturday,August 29, 2020, 05:31:47 AM »
The main point made in the Jalopnik article I linked to is that LED bulb upgrades to lamp housings that were designed for Halogen bulbs just don't work well yet.  They may appear brighter, but the beam pattern is wrong resulting in worse vision for the driver or glare for oncoming traffic, or both.  The opinions expressed in that article are those of Daniel Stern, a self-professed automotive lighting expert  (I'm not casting aspersions on his expertise, I just have no way to judge it).  Daniel Stern's website is here
https://www.danielsternlighting.com/
He sells/recommends E-Code (European spec) Cibie H4 7" round halogen headlights.  The Bus Depot website claims that the Hella version is comparable to and cheaper than Cibie.  Both Daniel Stern and Bus Depot recommend getting the E-Code units.  Bus Depot also does not recommend using H4 LED bulbs with the designed-for-Halogen headlight.
« Last Edit: Saturday,August 29, 2020, 05:35:22 AM by gideon »
« Reply #46 on: Saturday,August 29, 2020, 07:33:02 AM »
I read through some of the articles from that guy, Daniel, and he seems to know what he's talking about. And, like you, I don't know a whole lot about it, so I choose to believe him.
I think I saw some guy on YouTube say to get LED bulbs that mimic the H4 bulb for retrofitting a halogen lamp. He's probably right that that's the best you can do but as Daniel points out, it's not good enough.
I had an email conversation with a guy on the yahoo group about LEDs. IIRC, he chose an H4 replacement. He said it was much brighter and probably due to how low his car was, he didn't get a lot of people flashing back at him so he was pretty happy. So I would suggest that the height of the lamp is an important variable and that maybe a little leeway on a worse beam pattern as long as it doesn't blind oncoming traffic (although I've been blinded by xenon or LED bulbs found stock on big pickup trucks).
That's a good link. I'll have to go back and check out your previous links.
« Reply #47 on: Tuesday,September 01, 2020, 09:08:54 AM »
Further on LED headlights, here is an article from the September 2020 issue of Classic Motorsports:
https://jbcollier.smugmug.com/Lotus-Europa/i-FDcJfw5
https://jbcollier.smugmug.com/Lotus-Europa/i-zFcXQnJ
The beam pattern looks pretty tight with minimal scatter.
Offline Lotsof 3146 R
« Reply #48 on: Saturday,September 12, 2020, 11:21:55 AM »
Not for the purists ...
High output led headlights with side lights and indicator lights.
Low power - so you don’t need a relay
Low cost £25 for a pair for eBay (Land Rover defender halo led)
« Reply #49 on: Saturday,September 12, 2020, 11:22:57 AM »
Sidelights
« Reply #50 on: Saturday,September 12, 2020, 11:23:33 AM »
Indicators
« Reply #51 on: Saturday,September 12, 2020, 11:24:13 AM »
Beam
« Reply #52 on: Saturday,September 12, 2020, 12:07:44 PM »
Now I'm torn,  between halogens and LEDs.  Have you compared these with halogens for lighting the road at night?
« Reply #53 on: Saturday,September 12, 2020, 12:19:34 PM »
These are great for lighting the road - there are some inferior ones - look at he lens layout.
The prices vary hugely on eBay - from 23 to 70 plus.
I need new lights to convert from lhd and I’ve now bought a pair for the Jensen Healey
« Reply #54 on: Saturday,September 12, 2020, 12:51:03 PM »
Have you a link to the Ebay seller you got yours from?
Thanks
Richard
« Reply #55 on: Saturday,September 12, 2020, 03:50:53 PM »
Does the turn signal part work with the headlights on?
« Reply #56 on: Sunday,September 13, 2020, 03:59:24 PM »
Yes
Offline rjbaren
« Reply #57 on: Thursday,September 24, 2020, 07:02:26 PM »
An interesting website on lighting is "Danielsternlighting.com"   He covers LED and Halogen bulbs.  Regarding turn signals/side markers, he has two methods for making the front side markers flash with the turn signals.  He talks about headlight relays and many other lighting things.  No affiliation other than a satisfied customer.
« Reply #58 on: Sunday,October 25, 2020, 12:50:15 PM »
"I'd recommend that you convert incandescent gauge lights to LEDs."
Source?
« Reply #59 on: Sunday,October 25, 2020, 03:43:13 PM »
Here's a thread on converting pretty much all the lights on a TCS except the headlights to LEDs: http://www.lotuseuropa.org/LotusForum/index.php?topic=891.msg6614#msg6614
