Author Topic: Transaxle sump/fill plugs  (Read 500 times)
Offline Bodzer
« on: Sunday,July 05, 2020, 11:00:39 AM »
Evening everyone,
Are the transaxle sump and fill plugs interchangeable?
Cheers!
Re: Transaxle sump/fill plugs
« Reply #1 on: Sunday,July 05, 2020, 11:40:46 AM »
Yes.
Also you can get 8 pt. sockets for those plugs (I believe they are 11mm).
Offline Bodzer
« Reply #2 on: Sunday,July 05, 2020, 12:14:49 PM »
Thanks BDA,
The drain plug head is pretty rounded but the fill plug is fine. I’m going to swap them over. Thanks again for the help.
« Reply #3 on: Sunday,July 05, 2020, 02:51:36 PM »
You can weld/braze a nut to a rounded plug and you're back in business.
« Reply #4 on: Sunday,July 05, 2020, 03:45:29 PM »
The drain plug has a magnet attached.
Offline Bodzer
« Reply #5 on: Monday,July 06, 2020, 12:17:38 AM »
Thanks chaps!
The sump plug does have an indent in the end but no magnet. Perhaps it’s still in the transaxle! The square nut is 10mm. The fill plug on the other hand is 11mm and has 3/8 stamped on the inner end.
