Author Topic: Outer wheel bearing number, 1974 T/C  (Read 312 times)
Offline kram350kram
« on: Sunday,July 05, 2020, 09:37:33 AM »
Took the wheel bearings out, inner has a Timkin number but the outer has no number. Does  anyone know the outer bearing number? Thanks
Re: Outer wheel bearing number, 1974 T/C
« Reply #1 on: Sunday,July 05, 2020, 10:04:48 AM »
I assume you're referring to the front wheel bearings. They are both Spitfire units and you should be able to get them at any parts store or on line at Moss Motors, Victoria British, British Parts Northwest, Rimmer Brothers, etc.
If you're talking about the rear bearings, the outer bearings are: SKF or FAG 6206 2RS; NSK6206VVC3E-CSR1S5; NTN 6206LU, NTN6206LB
FYI there are parts cross reference links and a lot of technical information here: http://lotus-europa.com/manuals/
Offline kram350kram
« Reply #2 on: Sunday,July 05, 2020, 01:42:50 PM »
Thanks !
