Author Topic: 365 Transmission Output Shaft Seals Replacement  (Read 2442 times)
Offline surypap3
Re: 365 Transmission Output Shaft Seals Replacement
« Reply #30 on: Saturday,June 20, 2020, 11:43:16 AM »
Move the wheel while in neutral,  you are trying to turn the gears on the output side so the tips of the teeth don't line up with the input side.  I think you might possibly need one of the rear wheels on the ground,  or stopped from rotating, so the diff engages with the gearbox on the easiest side to turn (ie the one off the ground you are turning!)
I gave the wheel turning a whirl (so to speak), just did not happen. I think I am close to looking for someone who could open the case and knows his way around at this point. Any ideas?
« Reply #31 on: Saturday,June 20, 2020, 08:19:08 PM »
Someone check me on this but I recall removing the rear cover should be done with a particular gear engaged.
I'm sure it's in the manual.
